Who are the 205 Gurus in Melb?
    Member Bugsy1701's Avatar
    35
    Default Who are the 205 Gurus in Melb?
    Sydney has Peter T
    This morning my 205 started making an intermittent noise thru the drivetrain
    Are there any AF'ers with 205s in Melb who would be kind enough to have a listen/drive over the weekend?
    Bugsy
    88 205 GTi
    I wonder what it's like to be grown up?
    Jul 2004
    nth balwyn, victoria
    1,428
    Quote Originally Posted by Bugsy1701
    Sydney has Peter T
    can you describe the noise in more detail .
    also when it happens ie-cornering,starting off,stopping,accelerating hard. etc.
    someone may be able to diagnose the problem at hand and youll know where you stand in regard to repair costs and part availability.-BAZZ
    35
    Baz
    Thanks for replying, I know from past threads that you and a few others have done extensive work on your front ends hence the plea.
    Driving this morning its sounds a bit like an engine mount, there is a clunking sound on take of and a similar sound going on and off the throttle at low speed at high speed it is barely noticeable. I am not getting any feedback thru the steering. where do you suggest I look first?
    Regards Bugsy
    Bugsy
    88 205 GTi
    Fellow Frogger! amcc's Avatar
    Sep 2003
    Marraweeney Victoria
    311
    prob not engine mount. have a look at top and bottom mounts tho. they do wear out quite quickly but don't generally cause any dramas
    drive shaft ie cv joint noise is more likely in my op. hav a look c and to c if u can c if any of your drive shaft boots have split. there will be grease flicked everywher if they have. also c when it happens, full r lock, full left lock, all the time... good luck
    French - 92 205mi16, 87 205gti and spares
    Other - Amarok V6, Iveco Daily 50C17, Isuzu 600
    35
    No noise when I turn lock to lock really,
    CV boots look ok
    The knocking noise persists when I am stationery and rev motor
    Any suggestions welcome
    Bugsy
    88 205 GTi
    35
    Problem solved thanks to David at French Connection : Broken lower engine mount.
    Very relieved thats all it is will replace all mounts.
    Wont get fixed till Thursday so I have to slum it in the Prado till then
    Thanks to Bazz and AMCC for your input
    Cheers Bugsy
    Bugsy
    88 205 GTi
