205 gti electrical prob
Results 1 to 15 of 15
    Aug 2005
    27
    Default 205 gti electrical prob
    When I put the lights on full, or high beams something triggers a quick engine cut out, and if i keep doing this the dash light (efi or ignition froblem) flashes on then goes off after 30 secs or so.
    Is this a common problem? coz autoelectricians are expensive.
    Aug 2005
    27
    Now the warning light is constantly on, Im thinking this is just a short coz there doesnt seem to be any FI or ignition problem. Any ideas?
    Member Boldy's Avatar
    Jul 2005
    Auckland
    47
    Quote Originally Posted by spiral27
    Alternator perhaps? Can you measure the battery voltage while the engine is off, then when the engine is running?
    Try pulling a diagnostic code to see whats causing the warning light.
    Aug 2005
    27
    Sorry, this is all new to me, but how do you get a diagnostic code?
    Jul 2005
    Auckland
    47
    whoops my bad, it would appear not all GTi's have a diagnostic fault code capability.
    "The Jetronic ECU on most GTIs doesn't give out fault codes, only the later Motronic ECUs in the Cat models do"
    can anyone confirm this?
    Aug 2005
    27
    Mine is deffinately pre cat. It is a very strange problem, it only happens every now and then. And since this morning the warning light has gone off.
    Fellow Frogger! Justin B's Avatar
    Aug 2003
    Lugarno, Sydney
    236
    If your car is a 91, then it will have a cat.
    Pugsley The 1987 205 GTi Peugeot
    Aug 2005
    27
    I have found out from the previous owner that it is just an earthing short, but not serious, and that its a character trait. The fuel stopping for the short while during the short causing the engine light to come on. Guess Ill have to drive during the day heh?
    SMP addict pugjet's Avatar
    May 2002
    Enruoblem
    2,098
    Quote Originally Posted by Justin B
    all oz delivered gtis had cats.
    easiest way to destinguish if yours either runs a jetronic ecu or a motronic ecu, is that your 75kw (s1 & s2 - early tail lights, orange front light indicators, 14" rims pre 91) will run the jetronic, and 90kw (s3 - later tail lights, clear light indicators, 15" rims) will obviously run a motronic ecu.
    i thought all series of gti gave out fault codes.
    anyone care to elaborate? i'd be interested.
    who here has the link to the codes? i lost the link
    btw, spiral welcome to af. never thought earthing was a character trait - just bad wiring , actually... but having said that, ive never had any electrical problems with either my gtis.
    current frogs :
    '94 s3 alpine 205GTi
    daily ding magnet: '98 1.8 16v citroen xsara
    previous frogs:
    88 S1 205GTi
    '95 306S16
    gimme corners. . .
    Fellow Frogger! Dijon16's Avatar
    Jan 2005
    382
    This is vaguely similar to a one-off problem I had to my Mi16, where I flashed and it compeltely died. I had to call NRMA, and in a fit of friendliness and efficiency, he quickly traced the fault to bad wiring way under the dash.
    It was a couple of the thicker wires under the steering column and above the pedals that had been modified before I got the car, I suspect to fit the after-market cruise control that I had promptly taken off the car when I got it.
    The wires had been fairly crudely cut, terminated and rejoined, and he let me know that it was a significant fire risk. They were already blackened, and this was confirmed when I had them professionally repaired.
    Why I am relating all this is simply because of the risk. Peugeots and carfires seem to be strange bedfellows for whatever reason. Don't risk it.
    Jul 2005
    Auckland
    47
    well I got my Vin number, then went here
    http://www.205gtidrivers.com/info/techspecs.html
    and found out I had a XU9JA-D6B, 90kW which according to that page has a LE2 Jetronic. Mine is a 1989. I thought you could pull fault codes from that, but now I'm not so sure.
    Aug 2005
    27
    OK well then its motronic...
    thanks.
    Now then how do you pull a fault code? sigh..
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    thanks.
    If you don't have a cat, then you've either got a private import or someone's ripped it out.
    All cars since I think it was '86/7 were fitted with cats as a matter of law which is why the BX16V series one (released 1987) was never imported out here.
    If you know what one looks like, it's just as easy to stick your head under the car and directly under the driver there should be a flat looking muffler that is only about 18" long; that's the cat.
    As far as reading the codes; take a look at the common fixes board or do a search. I'll save you the trouble;
    Citroen BX TZi ECU diagnostic codes
    That's for a BXTZi which should be the same as your car.
    I have the K light on in my 16V at present and when I get around to it I'll do a read out of the codes. Don't panic, it only tells you that something's malfunctioned.
    If you only want to get rid of the light, disconnect the battery for an hour or so and that will clear the memory of the ECU and you start all over again.
    Alan S
    PS. A word to the wise. Forget taking too much to heart as regards advice on models from overseas. They got a lot of models we never saw so using them as reference can at times be misleading. As an example, the BX was not fitted with the cat in the UK as per regulations until 1993. Prior to that it was optional, yet we had all of our BX past '86 fitted with them and I'm fairly sure the Pugs were the same. They also had a 2 litre BX16V as well as one with a steel bonnet neither of which we saw. I point this out so that you don't start following well meaning but incorrect advice from people very knowledgeable on the 205 in thier region but not as regards our local scene when it comes to models imported.
    Member MayheM's Avatar
    Apr 2004
    Cheltenham, Melbourne VIC
    59
    Sounds to me like the previous owner was just lazy and didn't want to look into the fault!
    All cars electrics will have there own "traits" and tracking a electrical fault will probably be different for everyone. Over the last year or so I have been sanding/adjusting and replacing lots of plugs as the originals are all diseased with surface rust on the connectors, causing failures and shorts.
    The problem you are having happened to me also... and sounds identical. Before I went straight to the auto elec and brought a new alternator, I just ran a few tests. By using a multi-meter I noticed that the Alternator was working intermitedly, therfore not always charging the battery. A couple of times I got caught out with a flat battery... even while driving, the car would lose all it's power, stalling when the engine got to idle speeds. A quick jump start, the alternator is charging again, I get home.
    ANSWER: I pulled the alternator out, sanded/cleaned/tightened the plug on the body of the alternator, re-fitted, never had a problem since. VERY simple! (the French didn't make plugs to last!)
    MayheM
    Aug 2005
    27
    cool thanks i'll give that a try.
    205 GTI '91' Series III - Sorrento Green...Slightly Stock
