l0ocation and bypass of 504 detent(?) switch
Results 1 to 7 of 7
    Jun 2004
    156
    Default l0ocation and bypass of 504 detent(?) switch
    I've finally (i think) traced the non start electrical problem to a detent switch that (finally) died after the mechanic had replaced the starter motor at my request after chasing the intermittent problem and not finding one....
    Naturally, the car died permanently 2 days after the starter motor was replaced. I've since changed the ignition switch to another and back again without changing the situation.
    Where is it (the switch) and can it be easily replaced or even temporarily/permanently bypassed?
    12,269
    Quote Originally Posted by BarryC
    the switch should be underneath the car and mounted on the tranny where the selector goes
    you can by pass them
    you will have 4 wires
    2 wires are for the reverse lights and the other 2 are for the lockout
    from memory the 2 larger ones are the ones you need to bridge but just check your wireing
    hope that helps
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Perth Western Australia
    2,694
    Default 504 detent.
    Barry C,
    You will find the detent/start inhibitor relay between the battery tray and screen wash bottle. Will have the brand "Mixo" on it.
    If the gearbox switch is faulty it may affect your reverse lights as well.
    Servicing a new 504 years ago with a ZF auto we had a lot of strife with these. I think it was cured with an auxilliary relay.
    Jun 2004
    156
    Default ON a BW as well?
    I assume this relay and diagnosis also works with a BW 35 as well? I'll go outside and have a look
    Quote Originally Posted by Wildebeest
    Barry C,
    Aug 2003
    Perth
    925
    Default Detent capers
    I knew a guy once who removed the detent and one day started his car standing outside of it with one foot on the accelerator.
    Result it took off around the BigW car Park in Bunbury with his right leg emulating a skate board rider pushing for more speed.
    They towed eight other cars away by the time it was brought to a halt center punching a car and pushing it into another 2.
    One of the written off cars had just been picked up brand new from the dealer 500 mts down the road!
    I guess they are there for a reason.
    Graelin
    2,694
    Default 504 detent/relay
    BarryC.
    Sorry, I thought, for no reason, you meant BW 35.
    Graelin's post re by passed inhibitor switches. Burn It Into Your Brain!
    Jun 2004
    156
    Default Found the relay
    Found the relay
    Will get the mechanic (not me) to investigate - no I don't think it's a good idea to bypass it. They're not cheap to replace, but hopefully it's the relay and not the switch itself
    Barry C,
