Fuel Economy - 405 Mi16
Results 1 to 9 of 9
    Fellow Frogger! Roland's Avatar
    Perth
    727
    Default Fuel Economy - 405 Mi16
    Well I finally got my November '92 Mi16 on the road after a complete overhaul of the cooling system after I purchased the vehicle at Easter time.
    It runs beautifuly.
    One of the first things I had to do was drive from Perth to Geraldton and back (about 900Ks).
    I calculated that I got 35 Miles per Gallon (8.06 litres per 100 Ks).
    The next tankful was used for city running which I calculated at 31 Miles Per Gallon (9.10 Litres per 100 Ks)
    Is this what everyone else is getting?
    I expected a bit more as I used to get 36Mpg in the country in my 505 estate which is heavier, bigger, carby, older etc.
    Thanks in advance
    May 2004
    West Melbourne, VIC
    111
    Since i got Mi16 few months ago, my average distance travelled for each full tank is about 500km, for about 75% city traffic, ocasionally go wild with the accelerator, but I only fill it up once a month 5 minute drive from home to work well, the furthest i get from a full tank is about 612km.
    24
    My dad putts around in his '89 s1 and does usually less than 7L/100km for mostly outer suburban driving. Probably not a very comparable result, however...
    '97 306 XR Sedan
    al
    al is offline
    1000+ Posts al's Avatar
    Dec 2004
    2,012
    I get about 500kms from 45-50L around the city, but on a trip i can get up to about 750.
    I think 9 litres per 100kms is pretty decent around the city...
    405 Mi16 - Sold - Now back
    205 Mi16
    505 GTi
    16,536
    Don't complain.... Just worked out my fuel economy for the old CX ... Would you believe 21mpg driving to work and back
    It's the most torturous work a car can do though. Every start is a cold one, then it's only 5kms to work. In that 5kms there would be 15 intersections Damn that's expensive running when she's drinking optimax.
    The old BX (same as the 405) always return high 30's doing the driving you describe, and low 40's when cruising the highways.
    Fellow Frogger! DejaVu's Avatar
    Sep 2004
    Croydon, Melbourne
    693
    Quote Originally Posted by al
    yeah, thats about what i get too. tho sometimes i like to give the car a belting, so its not so economical then...but from 50 litres i generally get about 500kms.
    2013 Megane RS 265 Trophy
    Perth
    727
    Quote Originally Posted by DejaVu
    Thanks everyone - seems I am doing OK then.
    7,487
    It should get 35mpg at a steady 120, and 43mpg at 90, with 95/96 octane fuel.
    12,269
    Quote Originally Posted by rprince3op2
    i used to travel from rockhampton to goondiwindi which is around 750km's in my old Mi-16 on one tank of fuel and a lot of the trip was cruising at around 150-160km/h
    i would pull into the servo at the border with the fuel light on
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
