205 Gti Wheel Alignment
Results 1 to 8 of 8
    New Zealand
    36
    Default 205 Gti Wheel Alignment
    Hi Team,
    I've a 1988 205 Gti 1.9, 15" std wheels with michelin 185/55/15 tyres and Took the car in for a wheel alignment the other day. The only thing the alignment specialist said could be adjusted was the front Toe setting.
    Is he correct is saying Front camber and caster and rear Camber, caster and Toe is Not adjustable ?
    I did notice the steering wheel is now pointing straight ahead after the Toe in adjustment. I run 29 psi in the rears and 30psi in the fronts.
    Kind Regards
    Peter
    Fellow Frogger! 20FIVE's Avatar
    Jun 2004
    Houston Texas
    150
    Hi Peter, thats correct only the Toe-in/out adjustment is adjustable on the front end. Some specialists can manipulate the camber/caster slightly if it is out.
    Not too sure what they do on the rear. Normally warn bearings on the trailing arm shafts are the cause of miss-alignment.
    Member Certifiable's Avatar
    Sep 2004
    Queensland
    49
    Quote Originally Posted by Peter Arnold
    If I may go off topic, what front/rear pressures do people run on their 205s?
    I have Michelin Certis tyres (please don't laugh) which at Michelin's recommendation are 29psi front and 31psi rear.
    1980 604 [gone to a richer owner]
    1988 205 XLD Diesel
    Old Peugeots never die, they just get more peculiar looking.
    555
    I'm running preceda's in 195/50R15 at 37 front and back. I haven't had any wear issues since i got them put on, and the grip is fantastic under big loads because of the pressure. Ride is a little harsh though... but it was never soft.
    1987 205 GTI - Graphite Grey - 206k km's
    1988 MR2 Supercharger - Mica Blue - 114k km's
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,376
    I run 34 all round as i live on the worst roads in the world. Never had any wear issues
    Cam
    94 205 Gti Classic #9
    91 205 Si
    87 205 GTi Race Car
    555
    Ah, a nice bit of light reading, my wheel alignment report post "incident". I'd had the rear right trailing arm replaced and the beam rebuilt, and the front end needed work to take care of a bit of positive camber and a new wheel bearing, but alas, it wasn't enough:
    Rear end:
    Left Camber: -1*04'
    Right Camber: -0*41'
    Left Toe: -0.3mm
    Right Toe: -0.5mm
    Thrust (lol): -0*01'
    Front end:
    Left Castor: +1*16'
    Right Castor: +1*38'
    Left Camber: +0*10' - +0*13'
    Right Camber: -0*08' - -0*07'
    Left Toe: +15,5mm - +1.3mm
    Right Toe: +25.8mm - +1.3mm
    This analysis raises some questions... (questions the guys at bob jane didn't have the time or knowledge for/about).
    What the hell is up with that camber?
    How do i equalise the castor (and shouldnt it be about 3*15')?
    And wowie that toe in was chronic (i don't understand why the left had so much considering it wasn't involved in any incident ever...).
    Does my car need a lot of bending to repair? I really would like the numbers to be close to normal, and positive camber is far from normal.
    Fellow Frogger! casnell's Avatar
    May 2004
    Heidelberg/melbourne
    912
    Quote Originally Posted by Cubits
    Rear end:
    Left Camber: -1*04'
    Left Toe: -0.3mm
    Right Toe: -0.5mm
    Front end:
    Left Castor: +1*16'
    Now, not only did they disobey my number one command: Thou shalt put toe out on my 205, but this analysis raises some questions...
    How do i equalise the castor?
    What's the ride height?(centre to plastic trim)
    205gti
    555
    This thing's stock, so err, whatever is stock.
    The rear camber should've been fixed with that new arm/bearings... don't get it.
