205GTI Highway hesitation
Results 1 to 9 of 9
    Richmond NSW AUS
    36
    Default 205GTI Highway hesitation
    all,
    Just come back from a quick trip to Canberra. Whilst driving down the highway at 110kph, the car develops a hesitation at very odd intervals. The cars de-accelerates slightly/suddenly then picks up and runs fine until the next time. Car runs fine all other times and fairly flies along, also fuel economy is approx 7.5lt per 100 k (including fanging around Canberra).
    Theory 1: It is usually approx 1hr plus into trip with throttle position fairly constant. As the throttle pedal travel is so short, my foot could be twitching (too go faster maybe?) and causing the hesitation?
    Theory 2: Fuel pick up? Occurs at any tank level though.
    Theory 3: Ignition breaking down after long periods (although car does not get that hot)?
    Theory 4. O2 sensor????
    Any ideas or others have this problem?
    Merlin205
    Fellow Frogger! pugpete's Avatar
    Mar 2005
    Canberra, ACT
    231
    dodgy canberra petrol?
    I have had problems with some petrol stations down here. i used to work for one in Braddon and they used to talk about some pretty dodgy scams..
    if i dont use premium i get a bit of roughness when reving over 3 (when im doing 110kms its reving at about 3.5)
    hoep that helps
    205GTi Peugeot 1988 Graphite Grey for sale $2500
    brisbane
    2,913
    Change your fuel filter.
    cheers JR
    jr20516v
    Now:
    Exige SC [modded], 205 Si. 205 GTi , Megane R26 LY , Megane 225 [modded ]
    Previous: Honda EP3 Supercharged , 205 x34 [ including MI16 TURBO, 8v TURBO, CTI, 16V+TB's, 8V+TB's,] Fiat X1-9 X3, Beta coupes x5, Lancia Gamma coupe, GTI-R, Corvette C4, Fiero x5, Alpine GTA turbo, r5 GTT Dimma, 2cv ripple nose, Lotus Elise, 205 Dimma TT, Cliosport 172.x2, Clio rs 200
    Richmond NSW AUS
    36
    Quote Originally Posted by pugpete
    hoep that helps
    Nothing but the purest BP Ultimate from Sydney and Canberra. It happened on the way down (and on another trip to CBR the same).
    Merlin205
    Richmond NSW AUS
    36
    Quote Originally Posted by jr20516v
    cheers JR
    You think the filter is not keeping up due to blockage???
    7,487
    dirty, blocked, dribbling injectors
    Fellow Frogger! Kyle's Avatar
    Sep 2004
    Muswellbrook
    873
    Yeah maybe look at an injector clean also
    Richmond NSW AUS
    36
    Quote Originally Posted by Kyle
    So many small jobs adding up
    It needs a service soon where I will be getting a number of small niggles fixed: clutch cable lubbed, Injector weep (now to be cleaned), Fuel filter change new exhaust manifold (ceramic coated mmmmm), new door pins
    I still love my little Pug. The back way to the Hume is sooo much fun. Mulgoa rd to Wallacia, Oaks, Thirlemere (sp?), Tahmoor and then Bargo.
    Merlin205
    New Zealand
    36
    My 205 gti had sagging doors.
    Unbolted each door and rested each on a beer crate.
    Removed the very worn tension pins. Redrilled hinge and welded tang on the chassis to 8mm. Inserted new 8mm tension pins and refitted the doors.
    No slop whatsoever and just like new. use an air drill as they are a slim design and will enable you to drill the tang on the chassis straight.
    Pete
