505 hesitation
Thread: 505 hesitation
    Sep 2003
    Clifton Hill
    32
    Default 505 hesitation
    Hi all,
    My 505 is hesitating at 2500 rpm and above 2500 not doing anything.
    Below 2500 all is ok.
    Looking for some pointers
    1989 505 Gti II Wagon 323K and still strong.
    1990 405 Mi16
    1982 BMW 528i
    Fellow Frogger! 505 to the max's Avatar
    Newcastle
    380
    Quote Originally Posted by monty
    Hi all,
    Fuel pressure alright? Mine suffered a similar problem (slightly higher rpm though) and I replaced the vacuum advance hose and all was well. Might be worth a look (as well as fuel delivery). Pretty sure Graham would know the exact cause.
    Chris.
    1000+ Posts Gamma's Avatar
    Picton NSW
    1,412
    Assertiveness training should overcome hesitation.
    Check for leaking vac hoses.
    Clean air intake and airflow sensor.
    Air filter clogged.
    I occasionally have this problem with my GTI and find that a good fuel additive, (red X, Nulon, Lucas or what ever snake oil you prefer), can do wonders.
    /// 1986 SII 505 GTI
    2003 T5 307 HDI
    2013 LandRover90
    Fellow Frogger! 123abc's Avatar
    Feb 2005
    brisbane
    358
    hmmm, sounds like what mine used to do once.....
    found that the spark leads were exposed in the plug tubes, and they were earthing out. i could see a spark when looking down into the tube, arking from the top of the plug over to the tube....
    pushed the rubber cups, on the ends of the leads, back down over the plug and all was good..
    just a thought.
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,462
    Hi all,
    Sounds about right
    Sep 2003
    Clifton Hill
    32
    Default Thanks for the input
    Chaps,
    Thanks for the ideas will try and advise of success (hopefully ?)
    1990 405 Mi16
    1982 BMW 528i
