504 engine into a 505
Results 1 to 17 of 17
    Hobart
    1,496
    Default 504 engine into a 505
    Hello All,
    I have a mate who is really cash poor and his 505 engine is stuffed, so I thought i'd put a good 504 motor in I have here.
    None of this is a problem but is anyone aware if there is any issue with the 504 tin sump going into a 505 ? does it all clear or will I need to put the 505 sump on ?
    Ben
    1989 Peugeot 405 Mi16
    2000 Peugeot 306 XSI
    1973 Peugeot 504 GL
    Our most Southern Member (Tas)
    280
    Ben, Not what you asked but no problems going alloy sump 505 into 504. Has the car got aircon ?
    Regards Bob D
    Hobart
    1,496
    Hey Bob,
    AC is stuffed so it's coming out, this is a bit of a patch up job i'm doing......hate doing them but hey!
    1973 Peugeot 504 GL
    Fellow Frogger! Filldebin's Avatar
    Sep 2003
    Sweden
    177
    I put a diesel 504 motor into a diesel 505 thinking ittwould be easy, when I got to meshing the engine and gearbox together I discovered that the cunning engineers had slightly changed the pressure plate hole so it was differrent and therefore would not go without having to change the clutch plates etc; so check this first, otherwise I think it a good idea.
    My
    Fellow Frogger! PCOATES505's Avatar
    Jun 2002
    Gunbower
    399
    Ben
    why not swap the sumps over while you have both motors out, you will have to fit a choke cable, and I think the accelerator cable will need some modification, then there is always the valve recession problem to contend with, but every thing should bolt up ok.
    Pete
    I am gunna get another 403 on the road........one day
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    Melbourne, Australia
    2,930
    I've got a 504 Solex carb on my 505's engine. The accelerator cable had to be modified but other than that it just bolted on. It has a (working, yay!) automatic choke.
    Nick
    1983 Peugeot 505 GR
    Hobart
    1,496
    Thanks Guys,
    I've got everything covered bar the sump, i've done plenty of engine and carbie swaps all I want to know is will the 504 sump foul the crossmember or anything on a 505 I would assume not.....but
    Ben
    1973 Peugeot 504 GL
    Sep 2003
    Sweden
    177
    Quote Originally Posted by Filldebin
    My
    When I think about it , it might have been the flywheel that was different, but this is probably not the case with petrol engines as I am sure someone else would have pointed that out.
    Phil
    Hobart
    1,496
    how about the sump ?
    1973 Peugeot 504 GL
    Sep 2003
    Sweden
    177
    If you're asking me about the sump, I 'dunnae' on the petrol ones. I did not change the sump on the diesel ones.
    Hobart
    1,496
    But I dont want to change a diesel, i'm only interested in the petrol ?
    1973 Peugeot 504 GL
    mlb
    mlb is offline
    Voted Most Popular mlb's Avatar
    Jan 2005
    Devonport, Tasmania
    1,103
    Ben,
    Methinks it may be easier to just swap the sumps over.
    Fight for your opinions, but do not believe that they contain the whole truth, or the only truth.
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,895
    i would swap the sump anyway - i have heard the alloy 505 sump results in a stiffer motor - ie smoother. Plus it has the mounts for the AC compressor - worth keeping should you ever feel inclined to get it working again (dont think i could ever own a car again sans AC, but i think thats just me getting soft... )
    Sep 2003
    Sweden
    177
    Quote Originally Posted by Pug_405_Mi16
    D'Oh! I obviously mentioned it it as precautionary measure even if it is a petrol engine you are obviously talking about. Your concern is for the sump, but that does not preclude other problems that unexpectedly may crop up and in my simplemindedness I thought that I would point out a problem that might be okay and that I, however, came across, albeit, with the diesel engines and that was a 504 into a 505.
    Member 404ism's Avatar
    Dec 2004
    82
    Well i was just talking to my oldman about the converstion he did, and apparently the 504 sump will fit into the 505. but he put his into a GR, not sure what year.
    Quote Originally Posted by Isis View Post
    what is it about these cars that turn grown men into babies wanting a 2nd or 3rd identical rattle? now, wheres my wallet....
    Sep 2003
    Sweden
    177
    How did the conversion go? Was it only the sump or were there other problems that cropped up?
    I might want to do a similar thing here later.
    Phil
    Hobart
    1,496
    Phil,
    Didnt end up doing it, the car was too far gone to bother, I did some measuring up with a couple of spare sumps and there were no problems!
    Ben
    1973 Peugeot 504 GL
