Pug 504 Goes, But When Braking Hard Car Stalls
Results 1 to 14 of 14
    1000+ Posts Shobbz's Avatar
    Brisbane, Australia
    1,284
    As per the title the pug rolls forward yet again. Still no second throat opening on carbie, but for another timw perhaps.
    Installed a new booster (thanks Ray) and brakes work much better. The old booster was STUFFED.
    I still have the problem that when the engine is cold and when braking to a stop the car will stall?
    I though that the booster cyclinder replacement would replace this. Brakes all freshly bled, so guessing the problem is not there?
    Could there be air in the clutch circuit? The manual says that its not easy to bleed. I am up for the challange but is this the problem?
    The clutch does have a lot of travel and feels like its not being fully disengaged atm, maybe its just the syncro's. The clutch pedal is free for the first couple of inches of travel then it engages?
    Any suggestions?
    thanks
    James
    Previous
    2005 407 ST Exec
    1975 504 GL
    9,223
    From memory, Datsun 200Bs etc have a little valve in the vacuum line that eliminates this problem in those cars.
    Most annoying, we used to have it most of the time in the car I drive now, and I couldn't work it out.
    Nov 2001
    1,640
    Stalling during braking can be due to various things, James.
    Low carby float chamber fuel levels will do it. This can be caused by things like too low a float level, a sticky needle valve or a fuel pump that is on its way out.
    Too low an idle speed will also do it.
    So will a badly adjusted idling set-up generally.
    So will a worn shaft for the throttle butterfly, or badly set up carby linkages (sounds as if you have this at least if the second carby barrel won't open.)
    So will vacuum leaks, or a problem with the vacuum advance on the distributor.
    What do you have the idle speed set at?
    As to the clutch issue, it vwon't be related to the stalling during braking issue. Its worth sorting out though. I'd be suspecting maladjustment of the slave cylinder to clutch thruist lever linkage.
    Good luck
    Rod
    Rod's Home Page
    Rod's car page
    Brisbane, Australia
    1,284
    I had a look at everything and decided to do a car wide brake bleed.
    This fixed up the brakes to no end, they now stop
    Then as per the manual I did a dodgy clutch reverse bleed. Hooked up the left brake bleed valve to the clutch bleed and hopefully pushed the air out.
    Clutch operates a bit better, but I will have to get it professionally done.
    At least the car doesn't stall
    Thanks for the tips.
    Any ideas on the second thorat of the carbie?
    thanks
    James
    Previous
    2005 407 ST Exec
    1975 504 GL
    Guru davemcbean's Avatar
    Apr 2001
    Camden NSW & Selwyn NZ
    2,334
    Shobbz:
    Is the throttle cable adjusted properly? To do this you need to loosen where it clamps to the carby, then pull hard on the cable so that there's no slack, then tighten the clamping nut. This simple procedure often turns a slug into a reasonably sprightly car. My experience indicates that maybe 9 out of 10 504s have too much slack in the throttle cable which results in them being pretty slow.
    When I bought one of my 504s, the choke was disconnected and part of this mechanism was hanging down and jamming the second throat so it couldn't open. The bloke I bought it from said "I think it must have a taller diff". Yeah that's what it felt like, but it was just because the second throat wouldn't open and it had no go. After I fixed that 5 minute job that 504 would accelerate up most freeway hills in top gear, do 160km/h+ on a slight incline, 140 in 3rd, 100 in 2nd and 60 in 1st.
    Dave
    <small>[ 01 September 2003, 03:20 PM: Message edited by: davemcbean ]</small>
    NZ Fleet
    1976 504 Ti
    1984 205 GT twin carb
    1991 205 SI 1.6GTI motor
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    Brisbane, Australia
    1,284
    The cable is fairly tight; even so I can still turn the springy thing further down? Would the pedal be bent? Does that spring thing have to be all turned all the way down for the second throat to be engaged?
    My choke was disconnected too. I joined it back up, I think. Itís the little bar that slides into a cylindrical bar with a grove cut out of if?
    So close, I know it
    thanks
    James
    Previous
    2005 407 ST Exec
    1975 504 GL
    Apr 2001
    2,334
    You're pedal could be bent, or it could be loose at its pivot, which is a common cause of the same symptoms.
    The barrel on the side of the carburetor that the cable attaches too, needs to be able to turn all the way.
    It sounds like you might need to get somebody experienced to have a close look at your 504. It should be a quick problem to solve, but it's not always easy trying to describe these things in writing.
    Dave
    NZ Fleet
    1976 504 Ti
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    Brisbane, Australia
    1,284
    Looks like everything is in place.
    Apparently there is someone at stafford who is good with carbie's.
    Will see how it goes
    Shall check the pivot, haven't looked at that yet.
    James
    Previous
    2005 407 ST Exec
    1975 504 GL
    9,223
    Yep... same problem on this wagon I've just got going.
    It has the 505 engine (circa 1981) runs okay, idles more or less okay (some irregularity about idle speed) but when you pull up (brakes or no brakes) it will stall.
    So what do you reckon? This thing has to pass a blue slip in the morning...
    12,267
    float level ????
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Nov 2001
    1,640
    Ray Bell:
    For a solution in a hurry, try increasing the idle speed a bit above recommended? Sometimes these things are due to a slightly worn butterfly spindle not having returned fully when the idle speed was set anyway.
    Check for vacuum leaks too (cracked tube ends especially).
    Rod
    <small>[ 10 September 2003, 05:48 PM: Message edited by: Rod Hagen ]</small>
    Rod's Home Page
    Rod's car page
    9,223
    Thing is that this engine did everything right... dead right, when it was last in a car.
    That was about a year ago.
    Only change is that I've tried to make it so all the vacuum lines for the pollution control are in place.
    Brisbane, Australia
    1,284
    I bleed all my brakes.
    I also force bled my clutch. As per the haynes manual. Solved my problem.
    James
    Previous
    2005 407 ST Exec
    1975 504 GL
    9,223
    I've found ours too...
    The 'spout' on the top of the oil filler cap/breather was split... it actually broke off while I was hunting around the carby. Replaced it, things are fine.
    Thanks all...
