FEMSA alternator - '86 505
    Fellow Frogger! Roland's Avatar
    Perth
    727
    Default FEMSA alternator - '86 505
    Does anoyone know where I might get a diode pack and a regulator for a FEMSA alternator?
    Nov 2002
    Yarrabilba, Queensland
    2,758
    rprince3op2,
    Have you tried the usual suspects?
    Caravelle in Melbourne? 03 98909061...they have a very comprehensive French Car spares list, and one of the best mail-order services around.
    EAI if Caravelle don't have it, which would be rare.
    http://www.eai.net.au/
    if they fail, try Ingrams.
    http://www.ingram.com.au/
    Good luck
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
    19,211
    Default Faulty Diodes
    Quote Originally Posted by rprince3op2
    If the diodes are press fit into and aluminium "knuckle duster " bracket, since diodes are made to standard range of dimension, sometimes generic bosch or or lucas, motorola diodes fit.
    This can be easier than trying find spares for an odd ball alternator
    I assume you are talking stator diodes not field diodes. Standard 1N 4004 work OK as replacement field diodes.
    Press the old ones out (a drill of the right diameter put backwards into the chuck of a good drill press works well)
    Make sure you get the diodes the corect diodes as replacements: some are anode case and some cathode to case, usually they are all the same in the same bracket.
    Good luck
    Last edited by robmac; 11th June 2005 at 04:42 PM. Reason: Too many spelling errors !
    Fellow Frogger! Meggsy's Avatar
    351
    try a crowd called Ashdown Automotive - headquartes in Brisbane sell all that sort of stuff
    cheers
    Meggsy
    Current - 4007HDi
    Had - 407 HDI 406 SV 404, 504, 505 GR and STI. 405 GR ( carbie version) STI, MI16
    And an Austin 1800
    Learnt to drive in 203 Convertible and a 403 SW
    Perth
    727
    Problem solved - got a reconditioned Valeo from the wrecker ($60).
    WOW - does a charged up battery make a difference when starting!
