504 dodgy fuel gauge
Results 1 to 11 of 11
    Fellow Frogger! sparkey's Avatar
    Apr 2005
    374
    Default 504 dodgy fuel gauge
    Does anyone have a suggestion why a '78 504 fuel gauge is occassionally dropping out? It's konked out one minute and then fires back into existance monentarily before going back to sleep again.
    Sparkey
    12,265
    Quote Originally Posted by sparkey
    Sparkey
    bad connection and you will find it will most probably be on the dash binacle itself
    i had the one in the 604 do the same thing not so long ago so i placed a new wire in to bypass the circuit board and all is now good
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Fellow Frogger! sfrawley's Avatar
    Feb 2001
    Goolwa SA
    339
    If it happens at the same place on the gauge every time it's probably the sender unit in the tank.
    Stephen
    '03 P406 HDI
    '16 Renault Master
    Fellow Frogger! Roland's Avatar
    Perth
    727
    Quote Originally Posted by sfrawley
    Both my 505s do that as well.
    They use about 1/4 of a tank then the needles jump around a bit for a day or two then register nearly zero for the rest of the fuel load. They still, however register the low level warning light.
    I keep meaning to have a look at the senders but haven't got round to it yet.
    Interestingly one car has been doing it for about 2 years longer than the other car and guess what - one is an '86 model and the other '88.
    So it would seem that it may be a standard replacement item at about 300k miles!
    12,265
    all those symptoms are exactly what i had
    what i did to test was to run a wire from the tank sender to the guage for a few days to bypass everything to make sure it wasn't the sender then placed the wire in the dash to fix everything up
    it was only a short bit to bridge on the dash that couldn't be seen as broken but as i needed to know that the sender was ok i just bypassed everything to test it
    1 x 2018 3008
    Fellow Frogger! 123abc's Avatar
    Feb 2005
    brisbane
    358
    also sometimes what may happen, and happend to me....
    the sender in the tank has a little curved copper tab that slides up and down a very thin wire copper coil, remember the old figure 8 race car sets when you were a kid, with the hand held plunger speed control that you operated with your thumb????? exactly like that worked....
    anyways, the little copper tab eventually wears out and so leaves a sharp edge rubing on the very fine coil, rather then a nice smooth curved face, and a quick fix is to pull apart the sender and bend the tab around a bit more so the worn section cant catch on the copper coil....sounds complicated but it'll all make sence once you pull the sender apart and see with your own eyes.
    to pull the sender apart, grab a small blade screwdriver and gently pry back the little steel tabs that hold the plastic cover on.
    Apr 2005
    374
    Default Dodgy gauge comments
    Thanks for all those suggestions. Now that I've stopped racing the 'stupid' bicycle for a little while, will slip the overalls on and get down 'n dirty.
    Sparkey
    Jul 2004
    nth balwyn, victoria
    1,428
    [QUOTE=rprince3op2]Both my 505s do that as well.
    [/QUO
    my 205 gti does the same thing.what puzzles me is that when you fill the tank up it works fine.when it gets down to about 1.3 tank,it jumps from empty to fuel level and back then is fine for a while.
    what gives????-BAZZ
    Perth
    727
    Quote Originally Posted by 123abc
    I pulled the sender out of my '86 505 Estate thinking I would 'bend the tab around a bit more' but my sender is a long aluminium tube which reaches to the bottom of the tank. It then started to rain so I didn't get much further and put it all back!
    There's a filter on the bottom which comes off easily but then there's a plastic plug which may not come out.
    Has anyone had any experience with this sort of sender unit?
    12,265
    Quote Originally Posted by rprince3op2
    sounds like the same as a 604 type
    yes you can pull them apart
    1 x 2018 3008
    Perth
    727
    More info please - like how to pull them apart - do i remove the circlip from the bottom and then the large plastic bottom plug will fall out and what will I find inside?
    Is it like two wires stretched form top to bottom and a vertical slider which bridges the wires or what?
    Ta
