205 GTI "STOP Light & Oil Pressure Drop" when Cornering
Results 1 to 8 of 8
    Fellow Frogger! Justin B's Avatar
    Aug 2003
    Lugarno, Sydney
    236
    Hi all,
    Tonight... I noticed that when turning a ahrd right, my stop light comes on and the oil pressure guage drops significantly.
    Once point straight again, or easing out of the corner, everything turns to normal.
    I've checked the oil, and from what I can tell.. everything is ok (i've an after market oil dip stick)...
    Thoughts? Anyone have a spare genuine oil dip stick?
    Justin
    Pugsley The 1987 205 GTi Peugeot
    Fellow Frogger! Andreas's Avatar
    Sep 2000
    1,200
    low on oil, check the levels again with a pug dipstick.
    I never needed to bother checking the oil in the mi16, it told me itself the same way. wink
    7,481
    Did you know the oil temp guage in an Mi16 displays the oil level, when you first turn the ignition on?
    8,205
    <strong>original post by AdrianWuillemin</strong>
    Sounds great, enjoy the day. Please, just keep an eye on the oil pressure gauge and light. You will need to fit a sump baffle system if you are cornering hard and have good tyre grip.
    Picked this off another thread might be something you need to consider question
    08 C5 X7 HDi very Noir
    1000+ Posts CHRI'S16's Avatar
    Jun 2002
    3,298
    PeterT:
    Dont ever trust this feature tough, most service centers tell me its not the most reliable feature. used to trust it on my S16, until like youself and adrian and other servic fellows explaind just how much cornering affects sump oil levels.-cheers chris.
    ps, as for the thread q? how about at the next service empty out the oil into a measuring jug and see just how much was in there?
    ... ptui!
    Fellow Frogger! two-oh-philic's Avatar
    Feb 2003
    Glen Waverley, Melbourne
    419
    around when i first got my 205 it used to do that when cornering hard and eventually degenerated to hard braking it was oil level alright.
    EDIT: Sorry didn't read ur post properley. You already checked it. You could try adding a litre and seeing if it does it to the same degree. Unless anyone here can say that is a really bad idea. It wouldn't do it at all if the thing was right up to level on the dipstick.
    <small>[ 27 August 2003, 02:00 PM: Message edited by: two-oh-philic ]</small>
    205 GTi (S2 ) rolled
    '96 306XR "Sex" Black
    Aug 2003
    Lugarno, Sydney
    236
    Then... if someone with a genuine dip stick measure the distance from the full mark to the top of the stick (where it is seated).. THAT WOULD BE FANTASTIC!!!!
    I could then measure mine and mark the 'full' line.. and go from there??
    Justin
    <small>[ 27 August 2003, 06:55 PM: Message edited by: Justin B ]</small>
    10,934
    Justin B:
    Hi all,
    Justin
    Justin,
    Oil is cheap. Change it but leave filter in place. Fill with exactly the handbook quantity and mark the dipstick. Go for hard drive. See what happens. If OK, you have confirmed everything. If not OK, add 0.5 L and try again. If OK remark dipstick. If not OK? Well, maybe it's not oil level but something to do with your extreme cornering or oil pump or bearings???
    Just thoughts.
    Good luck.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    Citroën CX Pallas 1980
