paint coming off?
Results 1 to 2 of 2
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    Melbourne, Australia
    2,930
    paint coming off?
    The other day when I took off my front mud flaps I noticed that there is paint missing down near the front wheel arches:
    <img src="http://users.bigpond.net.au/njms_area/paint.jpg" alt=" - " />
    Its on both sides, although the paint hasn't come off as much on the driver's side, although it is all cracked in the same place. I suppose I need to buy some touch up paint and primer etc to fix that up, or won't it rust?
    While I'm asking about this, is it fairly easy to get rid of all the surface rust along the top of the rear windscreen? I've noticed its got a little worse since all this bad weather.
    cheers,
    Nick
    Nick
    1983 Peugeot 505 GR
    Hobart
    1,496
    Nick,
    To get rid of that rust u need to remove the rear windscreen ! as the rust is under the seals as well !
    once you clean it up you will need to get the whole roof sprayed ! otherwise it will look weird !
    Where the paint is off your sill's I have seen them cleaned back and primed and painted black...I think it looks smart like that !
    Ben
    1989 Peugeot 405 Mi16
    2000 Peugeot 306 XSI
    1973 Peugeot 504 GL
