205 A/C Wiring Diagram
Results 1 to 10 of 10
    Tadpole Super Josh's Avatar
    Jun 2003
    England
    28
    Default 205 A/C Wiring Diagram
    Does some kind soul have a copy of the wiring for the 205 A/C or could scan in the page from a workshop manual? My A/C is playing up electrically and as they aren't that common in the U.K. i'm having real trouble getting hold of a wiring diagram.
    Thanks Guys,
    Josh
    Miami Blue 205 GTi limited edition with Skip Brown 1.9S conversion Full leather interior, Skip Brown phase 2 suspension, Quaife ATB LSD, Grp N mounts, Grp N Exhaust, GTi 6 Brakes running Mintex 1144's and Goodridge Braided Hoses. Emerald M3D ECU to come soon.......
    7,487
    I though I did, but I don't. I have a spare harness. Tell me what's going on and I'll try to work it out.
    Jun 2003
    England
    28
    Thanks for looking Pete, my rad fans aren't working when the A/C is switched on. I would relly like to get hold of a diagram, do you guys get on in the Haynes manual or equivalent?
    Thanks again,
    Josh
    Fellow Frogger! Kyle's Avatar
    Sep 2004
    Muswellbrook
    873
    One of the fans should be switched by the ac ecu... and always be on when ac is on, perhaps you should check the ac fan relay to see if it has expired...
    I have a haynes 205 manual laying round here somewhere....
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Quote Originally Posted by Super Josh
    Thanks again,
    Josh
    Is it triggering the clutch on the compressor? It may be that you're low on gas in which case the switch on top of the receiver/dryer will be open circuit.
    Alan S
    Jun 2003
    England
    28
    Alan S
    Yeah the system is up on pressure, just that when you switch on the AC the fans just won't turn.
    Josh
    Tadpole 205GRIFFE's Avatar
    Mar 2005
    Holland
    18
    I have the Haynes Service and Repair Manual 205 on my website.
    The electrical/wiring diagrams are also included.
    Just download it!!!
    Link: http://home.hccnet.nl/e.a.kwint/Info/HaynesPeugeot205ServiceAndRepairManual.pdf
    205 1.9 GTI Griffe (1991)
    Check my website: WWW.205GRIFFE.TK
    Jun 2003
    England
    28
    Quote Originally Posted by 205GRIFFE
    Just download it!!!
    Thanks for the download. Unfortunately that manual is the same as the one we have in the U.K. without the A/C wiring So i will have to try another source, does the Aussie version have the A/C wiring diagram? Would anyone be prepared to scan it in for me? Nice Griffe by the way, would love to have one of those
    Cheers Guys,
    Josh
    7,487
    The 205 doesn't have any ECU control for the A/C or the fans. It's plain Jane stuff. I'll check on the weekend, but I'm certain that the relays are switched to low speed when the compressor is energised. So there should be continuity between the compressor wire and the low speed wire.
    I'd start by identifying the low speed circuit. ie the sensor on the side of the radiator. Pull the three wires off and work out which combination engages low speed.
    Jun 2003
    England
    28
    Thanks for that Pete. You are right no ECU control, this is my understanding of how the 205 AC works. Switch on the dash applies power to the temp control module underneath the heater box. If the temp of the evaporator is above ~3 - 4 degrees then a signal (probably just 12V) is sent through to the control box on the right hand wing to call for some cooling. The cooling fans are switched on low speed( the two in series) and if the refrigerant pressure as read by the pressostat is okay( ie above 2 bar(system not empty) and below ~ 20 bar(system over pressurised because it is working too hard)) then the clutch on the compressor is engaged and cooling begins.
    If the pressure of the refrigerant rises too high or the temp of the coolant rises above ~92 degrees, then the cooling fans are switched onto high speed(the two are in parallel).
    I have a question, if you've been with me so far. When the AC system is switched on, do the cooling fans run all the time? or only when the compressor is running i.e do they cycle in and out like the compressor does?
    Thanks again Guys,
    Josh
