Pug 205 front brakes
    Tadpole Jpug's Avatar
    Apr 2005
    Auckland/New Zealand
    13
    Default Pug 205 front brakes
    I am wanting to purchase some braded brake lines for my 205 1.9 gti
    but am unsure on what brake calipers I have (girling or Bendex)
    and if it makes any difference to my order? ie brake hose fittings different
    I have a haynes manual and it sheds no light on this.
    Any help would be much appreciated. thanks
    Fellow Frogger! Justin B's Avatar
    Aug 2003
    Lugarno, Sydney
    236
    G'Day,
    Bendix vs Girling
    Others may be able to confirm or debunk this but my understanding is:
    Bendix:
    The inside and outside pads are opposite of each other (not off set)
    Girling:
    The inside pad is offset (slightly lower / higher) when compared to the outside pad.
    The Haynes manual identifies this clearly in section 7 from memory (or is that gearbox and 9 is the braking section)?
    Regards
    Justin - Former 205 GTI owner
    Quote Originally Posted by Jpug
    Pugsley The 1987 205 GTi Peugeot
    Apr 2005
    13
    Thanks for that.
    I checked out my haynes manual and all I could determine is that it seems
    that all 1.9s have Bendex rear cailper Girling front and it is smaller engined
    models (xs & xr) that have Bendex front calipers.
    Does this sound ride?
    Aug 2003
    Lugarno, Sydney
    236
    I had a Series one (6/87) 205 GTi 1.9ltr with Bendix front calipers
    Thanks for that.
    Fellow Frogger! briz205's Avatar
    Oct 2003
    Auckland New Zealand
    894
    Hi,
    I currently have a set on trademe for sale. They both take the same brake lines so you don't have to worry which caliper you have. I'll deliver even if you live around auckland.
    Cheers Nick
    Auckland NZ -
    2000 Peugeot 406 Coupe, Dark Green.
    2001 Renault Clio Sport RS, Silver.
    Brisbane Aus -
    1989 Peugeot 205 GTi, Light Blue.
