405 Keys
Results 1 to 10 of 10
Thread: 405 Keys
    Jul 2004
    896
    Default 405 Keys
    Have lost a key......
    Are the remote locking/unlocking codes (when using the button on the key) tied in with certain key profiles???
    Decca
    Present --2016 2008 Outdoor / 2014 RAV4 Diesel (My utilitarian beast)
    May 2004
    United Kingdom
    338
    Hi
    The remote unlocking code for a 405 isn't tied to the metal key part.
    You can find the remote unlocking code number for your car on a yellow sticker that is attached to the remote receiver unit inside the roof consul or inside the keyfob on a white sticker.
    You also say you have lost a key, Please note that the lost key CANNOT be erased from the 405s security system & will still unlock your car if someone finds it.
    2003 Pug 206 GLX TU3JP
    Jul 2004
    896
    Thanks LeePower..
    So you cant alter dip switches or replace a chip to change the remote code in the car to match a new remote key?
    Decca
    May 2004
    United Kingdom
    338
    Hi
    I think it can be done but its a right pain to do, But dont quote me on that.
    It would be much easier to get a replacement set of 2 x remote fobs & matching receiver from a scrapped 405, Take you less then 10 minutes to swop.
    Or if you want a more secure system get an alarm with RF keyfobs installed.
    Jul 2004
    896
    Here we only get one remote and one ordinary key... If we got 2 remotes it would be no problem as the second key I only for emergencies and could just get that key cut at any hardware shop.
    But when you only get one remote..... Down to cost again .
    Decca
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    This any help?? It's for a Cit but I can't imagine there'll be a big difference.
    http://www.rwbsmith.plus.com/citroen2/plip/
    Alan S
    MrV
    MrV is offline
    Fellow Frogger! MrV's Avatar
    Jun 2004
    222
    hi,
    got my remote key replaced when i bought my car, as the button was missing. without the metal its about $145 from memory from peugeot dealer. you will need the code & proof of ownership to order.
    so its not cheap. might be worth a closer look at those electronics from Alan S. or, just stick the key in the door! however i found it very low down and i have to hunch over to get the key in. very annoying, especially when using the remote is so much more fun
    1998 D8 Blue Peugoet 406 Coupe
    1998 D8 Gold Peugeot 406 ST - Sold!
    1994 S2 Red Peugeot 405 Sri - Croaked
    8,923
    Quote Originally Posted by MrV
    hi,
    I know the guy who has the info I posted the link to and he has done a few over in the UK with an average cost of about $5 from some place like Dick Smith/Tandy Electronics.
    A few over there have tried what he recommends and reckon it's dead easy and works 100%
    Alan S
    Jul 2004
    896
    Alan S..
    many thanks for the link. very informative
    Decca
    farmerdave
    Guest
    Alan S
    Yes, this works very well but some of the components are a bit hard to get locally. Most of the info is correct but the later 405 fob uses a chip where the coding is integral rather than by drillings in the PCB- this makes things a bit confusing but isn't as bad as working out the connections from the number code.
    Farmerdave
