406SV - 2.0 ltr Turbo Fuel injection
    Fellow Frogger! Meggsy's Avatar
    351
    Default 406SV - 2.0 ltr Turbo Fuel injection
    Just had a real good look at my Emission data sticker in my 1997 406SV onlt to be a bit confuused when I saw the engine size as 1998cc ---- looking further it appears that the label is for a 2.0 ltr turbo Fuel injected engine -406 SV as per the attached. does any one else have a similar label apparently incorrecty fitted.... next question doessuch an animal exist???
    Atttached picture
    Meggsy
    Current - 4007HDi
    Had - 407 HDI 406 SV 404, 504, 505 GR and STI. 405 GR ( carbie version) STI, MI16
    And an Austin 1800
    Learnt to drive in 203 Convertible and a 403 SW
    Fellow Frogger! Paul Smith's Avatar
    Camperdown, NSW, Australia
    624
    That is the same engine as fitted to the XM & Xantia 2.0 Turbos - I did not realise that there was Pug equivalent, but it makes sense, given PSA's habit of mixing and matching.
    There's a road test here -
    http://www.ukcar.com/road_tests/peugeot/406turbo/
    The engine is not phenomenally happy in an Auto XM - I have driven one a bit, and it takes a while to get up and go - once rolling it really flies, though. Apparently they are very good for towing.
    I know someone with a Xantia CT Turbo manual and he says it is a real flier .
    Weird about the plate - having a bad day ay the factory? (Unless you've got yourself a turbo you didn't know about )
    Paul
    Paul Smith
    1974 DS23 EFI BW Auto
    1974 G Special 1220
    http://www.simplicitas.com.au
    351
    Gidday Paul
    No its really a 3.0Ltr V6 thats under the hood cost me enought to have the cam belt replaced recently now there is a rattle thats only there when its hot and I am up for a harmonic balancer that screaming it tits off.
    IOd still be interested to see what other 406SV owners have for emission labels
    Meggsy
    Current - 4007HDi
    And an Austin 1800
    Fellow Frogger! Pug4eva's Avatar
    580
    On my previous GTi, the sticker under the bonnet said it was 1.6litre! First time I noticed it I went cross eyed. Had few theories, like previous owner might have crashed it and replaced the bonnet off a wrecked 206 etc
    In Australia: 05 206 GTi 180 and '97 406 v6
    In Lebanon: 09 C3 Exclusive
    All in Silver
    Previously '01 206 GTi
    May 2004
    United Kingdom
    338
    Hi
    Yes Peugeot did produce a 406 2 litre turbo, It has the XU10J2TE engine fitted & pumps out 155BHP.
    Its basically the 8 valve 2 litre lump out the 405 with a turbo bolted on.
    Its not a very good engine ( thanks to the low pressure turbo ) It drinks fuel compared to the 2 litre 16 valve 406 & the turbo has a habit of seizing up, Best avoided.
    Also ones to avoid if they ever made it down under are the 2 litre HPI (Yes HPI petrol ) engines, They didn't last long in production & are very very troublesome, Also fitted to the Citroen C5 & it might have made a brief appearance in the Xantia
    Also thank god the 1.6 8 valve 406 never escaped from France, That is seriously an under powered car.
    2003 Pug 206 GLX TU3JP
    Fellow Frogger! KRISKARRERA's Avatar
    Nov 2002
    England!
    134
    I thought it was 150bhp.
    405 MI16
    170bhp
    Le lion va de la force la force!
