tyres rubbing on guards?
Results 1 to 14 of 14
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    Melbourne, Australia
    2,930
    I've got this suspicion that my front wheels occaisionally come into contact with the wheel archs. An example is when I come too quickly into a large dip while turning (like a large but gentle gutter on the side of the road) I hear metal rubbing against something. At first I thought it was my front mudflaps so I took them off, but it still occurs. Then I noticed that some of the wheel arch has become deformed a little up the top, like something pulled the metal lip down a bit. Have this photo of it. Since then I had pushed it back using a rubber mallet, but after a few more crunching entrances to our driveway and others, it has appeared again. What do you guys think? Fairly soon it will be getting 70 profile tyres (compared to its current 80 profile) so maybe that will give it more clearance? <img src="http://users.bigpond.net.au/njms_area/bump.jpg" alt=" - " />
    Nick
    1983 Peugeot 505 GR
    1000+ Posts silverexec's Avatar
    Melbourne, Victoria
    1,003
    Must have taken a fair amount of effort to bend the lip like that, are there any scuff marks on the side of the tyre? I would imagine there would be some scuffing or even bits of rubber missing if it's the tyre causing the lip to do that. It doesn't look as though there's much clearance there. Can't really think of anything else that could cause it, so the lower profile tyres might possibly fix it...?
    Richard
    <small>[ 11 August 2002, 07:31 PM: Message edited by: silverexec ]</small>
    - Richard
    Now: 405 SRI D70 '93
    - 2.0L manual
    Earlier: 505 GTi Executive '85
    - hence "Silver Exec"...
    25 GTX '86
    - manual conversion
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    2,930
    Just went outside and checked - even more is bent out since that photo, and there is scuffing marks on the tyre. Yet another reason to spend my tax return on tyres
    Nick
    1983 Peugeot 505 GR
    Fellow Frogger! Reno's Avatar
    1,260
    You can gets your guards rolled, and too be safe just try a 55 series tyre.
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    2,930
    LOL.
    I think my car would look a bit stupid with a 55 profile on 14" wheels clown
    Nick
    1983 Peugeot 505 GR
    Hobart
    1,496
    What about 65's Nick,
    They would be fine I would think ! 185/65/14's ?
    Ben
    1989 Peugeot 405 Mi16
    2000 Peugeot 306 XSI
    1973 Peugeot 504 GL
    1,260
    yar dude, see if you can get your Gurads rolled too!
    Apr 2002
    13
    lol pump the guard riiiight out haha. head_ban
    I am a Toyota Imposter... (2)
    Lilydale, Melbourne
    2,095
    I had 195x75x14 tyres on my 505 turbo diesel, which are taller profile than standard. I experienced this problem, but it only happens if you hit a bump or similar while you have a bit of lock on the steering. The tyre tread grabs the guard for the instant that it's at the top of the bounce and pulls a bit of it down like in your pic. It was no trouble for me to push it back into position by hand.
    I reckon 185x75 or 195x70 are the right size tyres for a 14x5 steel wheel on a 504 or 505. If your tyres are 80 series like you said I guess they are 175x80? Both alternative sizes above have a slightly lower sidewall height than these. You shouldn't really have any trouble with any of these 3 size tyres hitting guards if you're aware it can happen and allow for it.
    John
    John W
    1974 Peugeot 504 TI
    - now on the road
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    2,930
    True. It caught me off guard (no pun intended).
    I have 185/80 tyres. For it to happen you don't need to be on full lock, although it is morel likely to happen if that is the case.
    Thanks for the feedback everyone, I look forward to my new tyres
    Nick
    1983 Peugeot 505 GR
    Jun 2002
    brisbane
    45
    Nick from that photo your front spring's are sagged.Put new spring's in,the car sit's level,handles better and won't scrub the tyres.What happens is the strut is bottoming ouy on the bump stop because the spring is weak.Every 505 until the mid 80's sagged like that but only a few have ever been fixed properly.
    Fellow Frogger! DTwo's Avatar
    Melbourne, Victoria, Australia
    770
    I'm with Chuck on this one,
    The front end does look a bit low for a stock 505.....
    There is absolutely no reason why the tyres should hit the guards with (healthy) stock suspension, tyre and wheel size.
    btw,
    nice paint job there, looks like a nice 505
    <small>[ 14 August 2002, 10:43 AM: Message edited by: DTwo ]</small>
    ________
    Avandia Lawsuits
    Jun 2002
    396
    Nick,
    Get some 85 model GTI or STI springs. You shouldn't have any worries then, and your car will corner alot flatter two.
    Dave
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    2,930
    Thanks guys,
    I'll think about replacing the springs next year, we'll see how it all goes.
    For now I'll just get new tyres
    Nick
    1983 Peugeot 505 GR
