Rear End in a 205GTi
    Fellow Frogger! Justin B's Avatar
    Aug 2003
    Lugarno, Sydney
    236
    Hi all...
    THe rear end of my little pug goes 'squeak' each time the car goes up or down (i.e I sit in it, or get out).
    It also squeaks on the road.
    From what I've been told, it is some sort of ball joint at the rear (to do with the trailing arms?) that occurs on all 205's...
    Yes.. you can replace the rear end, however I've heard that there is an alternative where you drill a hole (somewhere) and fill the joint with grease.
    Any idea what I'm talking about??? any touhgts?
    thanks
    Justin
    [email protected]
    205 GTi 87 (with a slipping clutch, brakes that pull left, brake booster needing reco, rear end squeak, and a dash with more cracks then Bush's Iraqi war plan.) hehehe
    Pugsley The 1987 205 GTi Peugeot
    May 2002
    642
    Not sure about drilling a hole and filling with grease. The rear end on 205's run on needle roller bearings and require the rear torsion bar to be stripped and to have them replaced, also a good time to lower the rear of the car.
    05' Megane 225 Cup
    Aug 2003
    Lugarno, Sydney
    236
    Ok.. so If I'm going to remove this squeak.. what do I need to order in terms of Parts?
    Justin
    Fellow Frogger! DTwo's Avatar
    Melbourne, Victoria, Australia
    770
    Justin B:
    Hi all...
    thanks
    Justin
    [email protected]
    Are you sure the squeak is coming from the rear suspension?
    In my experience the noise is more likely to be the tailgate even though it seems related to suspension movement (as strange as that may sound)......
    Aug 2003
    Lugarno, Sydney
    236
    DTwo:
    Justin B:
    Hi all...
    thanks
    Justin
    [email protected]
    Yea.. I think (99%) that it still squeaks with the hatch open...
    jb
    770
    fair enough
