306 Clock - Outside Temp Question
Results 1 to 7 of 7
    Fellow Frogger! buzzlite's Avatar
    Dec 2004
    Wellington - NZ
    272
    Default 306 Clock - Outside Temp Question
    Jumped in the car tonight to find that the clock has decided to start dancing to the music !!!!!
    It's display is going mad, you get all the vertical lines on the display panel followed by the horizontal lines - maybe it's waving me goodbye - who knows.
    Any ideas on what has broken this time ?
    Quick, to the Poojet
    Jul 2004
    Mildura
    4
    Default 306 clock
    When power is interrupted (say battery change or fuse problem) the radio needs a reset using its code. This resets the outside temperature read.
    Failing that the other cause is a faulty wire in the loom going into the door (left side as temperature reader is in the exterior mirror on that door.
    Hope this helps
    Dec 2004
    Wellington - NZ
    272
    I have an after market Radio that doesn't require a code.
    Could it be a blown fuse ?
    So the Temp sensor is on the passenger door ?
    12,265
    press one of the clock buttons to see if iy stops waving and dancing
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Dec 2004
    Wellington - NZ
    272
    Thanks Pugrambo - with Buzzlightyear kids fork in tow - reset the clock and the russians have gone.
    Still leaves me wondering - what caused it to have a fit in the first place ?
    12,265
    Quote Originally Posted by buzzlite
    the battery terminals can be a bit dicky at times and so it may have flicked off for a split second and reset the works
    have you got the original screw type pug terminal on the positive side of the battery, the one that they have used since 203 days and they were no bloody good then ?
    if so then you need to loosen it off and push it down hard on the terminal and give it a good hand tighten
    they work loose over time
    why they still use them i don't know as they were no damn good back in the 50's either
    1 x 2018 3008
    Dec 2004
    Wellington - NZ
    272
    I'll have a look tomorrow - 10:30pm here and 13 deg outside and the wifes taken over my side of the garage with "stuff" so the poor wee 306 is outside.
