Hi
I have had problems with oil seeping onto fan belt which in turn flicks oil around the engine.
was told to check and clean appropiate hoses etc to help it breathe and to reduce pressure - which I have done.
Cause it was still happening, someone said that the timing cover was to blame. I got a new cover and seal which the local mechanic fitted for me. He reckons that the oil would be coming from a sandwich plate on the engine. If so how does it make it to the outside of the engine? The mechanic reckons that the timing cover and seal was ok!
