206 brakes; Pads & Discs?
Results 1 to 12 of 12
    Fellow Frogger! xonicjan's Avatar
    Nov 2003
    120
    Icon4 206 brakes; Pads & Discs?
    My mechanic just called and said I need my rear brakes replaced and that the discs and pads need to be done at the same time on 206's.
    Is this correct?
    1000+ Posts CHRI'S16's Avatar
    Jun 2002
    3,298
    If not, machine the discs, (depends on how badly scored they are). But the general rule is the pads and discs need to be beded at the same time, this works alot better when the disc surface is not glazed or scored, hence either the machining or new discs.
    Anothe alternative is to sand paper the disc surface, a trick that was tought by my fellow racers... - Chris
    ... ptui!
    Sep 2003
    North Parramatta
    3,997
    Quote Originally Posted by xonicjan
    Is this correct?
    Personally, I think it is only correct if the discs are worn beyond there minimum thickness.
    Whether or not it is true in this particular case, making blanket statements like "the pads and discs must be changed at the same time on 206s" always sets of alarm bells in my head.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Jun 2002
    3,298
    Quote Originally Posted by SLC206
    Don't forget its the rear pads and discs... without measuring or looking at it, its hard to say. - Chris
    ... ptui!
    1000+ Posts kermit's Avatar
    Jun 2002
    Inner city, Brisbane
    2,335
    Is this correct?
    Have the fronts ever been done? If not then I would question why the backs would go before the fronts. Discs don't necessarily need doing at the same time. If you trust your mechanic take his advice , if not get a second opinion.
    Cheers Simon
    >8-]
    Rendezvous Adelaide 2005
    My Flickr Photos
    206gti.net
    peugeot-206gti
    peugeot-307
    peugeot-407
    peugeotclub.asn.au
    Jun 2002
    2,335
    I agree Simon. Unless you have a good relationship with whomever looks after/services your car then I wouldn't be to keen to throw my money at them.
    Cheers Simon
    >8-]
    My Flickr Photos
    206gti.net
    peugeot-206gti
    peugeot-307
    peugeot-407
    peugeotclub.asn.au
    Nov 2003
    120
    Well seems that the discs are undersized.... my own fault for not gettin service done on car when it was due as last mechanic said the pads would need changing.
    What a waste of money....
    Sep 2003
    North Parramatta
    3,997
    Whoops.
    Ah well, rear discs aren't that expensive in the scheme of things.
    Simon
    Nov 2003
    120
    heh heh $400 bucks. Thats not 2 bad
    Even was shown the old ones. (pretended that I knew what I was looking at)
    Member flyNxsi's Avatar
    97
    306s and 206s have the same rear brakes. they have a naugty habbit of wearn out 1 outta 4 pads prematurely. just a crap design. most the time people will complain of a noise comn from the rear when braking cos the pad has worn out and is running on the backing plate of the pad which is METAL but keep driving! metal eats metal.thats probly why u need discs too.stop,take to a mechanic. plus the pad material is only 6-7mm thick new. doesnt take long too get through.
    12,265
    Quote Originally Posted by flyNxsi
    do they ?
    mine are all even on the GTi-6
    when the pads do get to the point they need changing i will only be changing the pads as the discs are fine and original
    ok it's a country car but it has also done a fair few k's in traffic and built up areas
    with 104k on it i think it has done well
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    97
    ye, most of the time. youre lucky. mine did it a little before i fitted EBC green stuff pads with dimpled and sloted dics. no issues with wear!
