knocking noise from front end, 205
Results 1 to 7 of 7
    Apr 2005
    NSW
    5
    Icon9 knocking noise from front end, 205
    Hi Guys
    any advice appreciated,
    i am experiencing a knocking noise from under the bonnet driving at very low speeds, either about to stop or just pulling away in 1st. I noticed a grinding noise couple of weeks ago but this has now developed into the knocking(i think). Its 92 205 Gti 130kms and has had every service since new.
    any ideas??
    SMP addict pugjet's Avatar
    May 2002
    Enruoblem
    2,098
    engine mounts perhaps?
    current frogs :
    '94 s3 alpine 205GTi
    daily ding magnet: '98 1.8 16v citroen xsara
    previous frogs:
    88 S1 205GTi
    '95 306S16
    gimme corners. . .
    Fellow Frogger! ruckus's Avatar
    Apr 2004
    491
    Hope it's not Drive shafts or cv joints. Is it any different under heavy steering at low speeds?
    Series 1 205 Gti
    '54 VW Beetle (oval-window)
    '71 VW Beetle (big-window)
    Mar 2003
    Location Location
    1,576
    Driveshaft would normally be "click click click" when making a turn so my guess is the gearbox level is down - top it up and see if that fixes it.
    Fellow Frogger! 20FIVE's Avatar
    Jun 2004
    Houston Texas
    150
    Default Knock Knock whos there?
    As Pugjet mentioned... typically your top engine mount on the cambelt side goes (unnoticed) and starts to develop a knock. Check for any rubber debrie in the area around the mount or even wear marks on the paint where the mount has been touching the body.
    Other locations which create knocking are the bottom engine mount which is less visable. This also has a connecting bracket which has a rubber bush. When this gets old the actual bracket hits the sub frame. while the big mount shows cracking. Easiest to check this mount and bush on a hoist by leavering the engine back and forth from below.
    Another one is the drop links for the sway bar, the lower joint on these bars wears and knocks. disconnect the bottom or top bolt and take the bar off at either end. Attempt to pull the joint apart with your hands - like what these dudes are doing with their beers and you may feel a bit of free play which will casue the knocking.
    best of luck
    Apr 2005
    NSW
    5
    Icon5 knocking from front end
    well thanks guys for the feedback
    any recommendations on who in sydney would be able to give an honest diagnosis of the problem without ripping me off?
    Ive heard the names PQ Automotive and Gladesville prestige cars been thrown around!
    What prices could I expect to pay for the replacement of:
    engine mounts
    cv joints
    drive shafts
    Apr 2005
    NSW
    5
    Icon5 Thanks for the feedback, who would you reccommend
    Quote Originally Posted by 20FIVE
    best of luck
    engine mounts
    cv joints
    drive shafts
