205 TD Electric Windows
Results 1 to 7 of 7
    UK
    3
    Icon8 205 TD Electric Windows
    I have recently bought a M Reg 205 TD, and the two front electric windows dont work
    I have never tried to fix anything electrical in a car before, so any help with this problem would be greatly appreciated!
    I've been told its most probably a problem with the fuses or relays, dont know what that means tho, so... erm... help! lol
    If anyone can let me know where to start, or even guide me thru finding and solving the problem, i will be forever in your debt
    TIA
    Jaymz
    Fellow Frogger! tassiediesel's Avatar
    Jul 2004
    Tasmania
    175
    Default Probably fuse or relay
    Quote Originally Posted by Jaymz
    TIA
    Jaymz
    Firstly, I'm insanely jealous. We don't get the 205 diesel here. Next, because we don't get it unless the electrics are the same as our petrol 205s we would be guessing. What year...."M" is about 1993?? How many doors? (You said "front" this suggests that there are back doors.) If it's a two door and both windows don't work, then a fuse or relay is the most obvious culprit. Be patient....205 owners that are Aussiefrog members will come to the rescue!
    82 Peugeot 505 Turbo Diesel
    78 VW Golf diesel
    80 VW Golf diesel
    84 Nissan Patrol MQ diesel
    UK
    3
    Quote Originally Posted by tassie505gti
    well... what can i say
    there are back doors, but they are mechanical windows, the two front doors are electric, and neither of them work. No motors moving, no noises, not a thing! If it is the fuses, how would i check this, and is there anywhere i can get a diagram or something to show me what to do?
    Christchurch
    13
    the fuses are on the passenger side in the glove box should have symbols showing you which one is for the windows. I have had a problem with the ones in my 205gti and the only way i could tell it was the motor was to check to see if there is power going to it. so get a tester and just see if there is 12v going to the motor if not then you know its in the circuit somewhere.
    good luck
    Fellow Frogger! michaelh's Avatar
    Apr 2001
    157
    205 switches have a habit of sticking. I'd try the cleaning the contacts first. Unplug the switches open them up and give them a good clean and see if that works. Should only take you a few minutes. Best of luck.
    UK
    3
    thanks for the replys, i will try cleaning them first, then see if i can get a tester and find out if its the motors.
    ill get back to ya if it doesnt work
    Member burkey's Avatar
    Mar 2005
    57
    Great timing on the thread, my passenger electric window on a 205 SI goes down slow for half the window them goes normal speed. I think a bit of lube on the window might solve the problem. What does everyone think for the lube?
