I hav ean sti and before that it was an sli wagon. this cara lways starts well when cold. after it has warmed up and been driven a reasonable distance thenleft, turned off that is, it starts and runs on less than four cylinders and takes a while to cantch on to the rest that are missing the longer it is left the less cylinders that fire until it reaches the stage where it won't. When the car was an sli I hot wired the cold start injector so it would always go until that turned off after 30 secs, a few goes like that and it would run no problem. With this new ( second hand ) motor the problem seems to be the same, although I have not hot wired the cold start injector this time. The only common items I still have are the fuel pump, pressure regulator and the injectors. I suspect the injectors are at fault, but at around $ 320 to replace them with no exchange I'm seeking another opinion.
