Dry Air Filter Oil. What the???
    Mar 2003
    Location Location
    1,576
    Hi all
    The instructions on this "filtre a air sec" packet read deal
    IMPORTANT. Before mounting, spray all foam surface with dry air filter oil. Part No. 9734.75
    What the hell's that?
    I've never heard of it.
    181
    Maybe it means "dry air" as in no moisture in the oil. Funny way to say it but it's french after all - non?
    Mar 2003
    Location Location
    1,576
    Hmmm, although it's a "dry" air filter (as opposed to the oil bath type in 404's etc) I think they mean it has to be fitted moist, sprayed all over with this stuff. Dunno.
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    It's only a guess, but on Briggs & Stratton I/C engines, they have a dry (paper) filter that has a thin foam sock that goes around it.
    When the air filter is serviced, you have to wash this sock in petrol, blow it dry & then ad a few drops of oil to it & ruffle it up in your hands so as to work the oil right through the foam; the idea being that this collects dust particles before they reach the paper filter & give the actual paper element a longer life expectancy.
    I would assume this is something similar.
    The terminology may be looking flawed due to a missing comma or the way it's being said.(ie)"Before mounting, spray all foam surface with dry air filter oil" perhaps should read
    "Before mounting on dry air filter, spray all foam surface with oil."
    Alan S
    181
    I think that sounds good.
    Top work Alan! dance
