Vibration??
Results 1 to 8 of 8
Thread: Vibration??
    brisbane
    47
    Vibration??
    I have had this problem for a couple of months now and it is starting to bug me. I have a vibration that occurs ONLY when I am cornering to the left at speed above about 40km/h. It sounds as if something is rubbing on either the rear of front right hand wheels. I took it to the place that fitted my tires and they hoisted it up and had a look but could find no signs of tires rubbing or anything like that. I has to be a problem on the right hand side because this is where the weight is shifted to when you corner to the left. The guy at goodyear said it could be a torsion bar problem but he admitted he had no real idea. Has anyone else out there ever experienced this or think they know the cause of the problem?
    brisbane
    47
    Sorry i forgot to tell you what car it is. It is a 1990 405 mi16. Done about 174 000km.
    392
    Can you feel it in the steering wheel?
    12,264
    check your mufflers
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    brisbane
    47
    Yeah sort of but i had a wheel alignment a few months a go. It sort of makes the whole car vibrate really. I'm not sure if the sound is resinating from the front right wheel or the rear right wheel. Would a faulty torsion bar cause symptoms like this?
    392
    Never had problem with torsion bar yet so couldnt tell what the symptons are. But check your inner cv joints.
    12,264
    pugrambo:
    check your mufflers
    i was dead serious when i posted this
    if the baffles are gone in your centre muffler they create a great vibration doing LH corners
    1 x 2018 3008
    1000+ Posts CHRI'S16's Avatar
    Jun 2002
    3,298
    pugrambo:
    check your mufflers
    yep.... happens in 306's with aftermarket exhausts too. They rub up agains the body/chassis - chris
    ... ptui!
