Vavle stem seals checking
Results 1 to 10 of 10
    Feb 2001
    493
    I found this on another site, would the same for every car? inc my little 205?
    A simple test that might reveal whether it is valves or rings:
    Warm the car up and hold it at moderate rev's (4-5k should be heaps. Don't worry, you won't hurt it), for a few seconds and the exhaust is clear. Abruptly take your foot off the gas and check for a sudden cough of smoke from the exhaust.
    cheers,
    joey
    Fellow Frogger! two-oh-philic's Avatar
    Feb 2003
    Glen Waverley, Melbourne
    419
    So which is which
    205 GTi (S2 ) rolled
    '96 306XR "Sex" Black
    Nov 2001
    1,640
    I would think so Pugsly. The production of smoke with sudden back off after higher speed running is a pretty commonly recognised dign of valve guide / stem seal problems. With rings you tend to get blue smoke under load instead.
    Rod
    <small>[ 16 August 2003, 05:50 PM: Message edited by: Rod Hagen ]</small>
    Rod's Home Page
    Rod's car page
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    If you're a bit "iffy" about the holding at the higher revs, another trick is to just point it down a hill & back off halfway down & gently accellerate when you're near the bottom; same result, big cloud of blue smoke = valve stems.
    As a rough rule of thumb, if she smokes going uphill it's rings & downhill valve stem seals.
    Alan S
    9,223
    And along the flat?
    Naturally that's a rocker cover gasket leaking onto the exhaust pipe...
    8,923
    Ray Bell:
    And along the flat?
    That'd depend on whether the car was going forard or backards at the time wouldn't it?
    Alan S roll_lau roll_lau roll_lau
    12,265
    Ray Bell:
    And along the flat?
    see if you had a PRV in there ray the rocker covers don't tend to leak so there you alleviate the oil on the exhaust problem
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    9,223
    Originally posted by Alan S
    <strong>That'd depend on whether the car was going forward or backards at the time wouldn't it?
    Turning left or right is more appropriate...
    Actually, the only time I had a real problem with this was when I had a broken bolt in mine a bit over a year ago.
    That left how many? Let me see now... one!
    Feb 2001
    493
    thanks all
    Nov 2001
    1,640
    Ray Bell:
    And along the flat?
    And if it happens with your foot on the brake, regardless of other things, its a a dieing master cylinder dripping onto the exhaust pipe and running into a loose join before the first muffler.
    Quite spectacular, this one, on occasion.
    Rod
    Rod's Home Page
    Rod's car page
