205gti cutting out under corners
    Member ilek300's Avatar
    Mar 2003
    99
    hey all,
    i've had this problem for a while now, my 205gti is cutting out under hard cornering, its like everything just cuts out, then as it straightens out then it suddenly cuts back in. any ideas on what it could be? thanks in advance
    2000+ Brad's Avatar
    2,404
    Checdk the plug on the wiring loom going into the ECU under the dash is secure. I had this once in my S16 when I hit hard bumps in the road. It seemed to happen more on the LH rather than the RH side. The ECU is on the left, took the connector off then reseated it and pushed it in firmly and the problem went away.
    Ipswich, Queensland.
    1,911
    If you are low on fuel this will happen as the tank is flat and wide, causing fuel surge in corners. I found I had to have at least 1/3 of a tank on the track.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    02 and 03 Renault Clios 1.4L
    NSW
    1,063
    Thats right, its fuel surge.
    On the track with decent tyres you'll need about 1/3-1/2 a tank to combat it.
    I'm fitting a surge tank to mine.
    Fellow Frogger! Justin B's Avatar
    Aug 2003
    Lugarno, Sydney
    236
    HI All,
    THere is a product floating about that helps to reduce the fuel slapping about in the tank (thus causing instability).
    I can't remember what it is called, but basicly it's a replacementtank thats made of a honeycomb construction, which stops the fuel sloshing about. I've seen it used in a few state c'ship rally cars to help maintain balance during switch-back stages...
    It also had teh added bonus of self sealing if the tank ever gets punctured. (Unless it's a gaping HUGE hole!!!!
    Justin
    MYT205:
    Pugsley The 1987 205 GTi Peugeot
