ABS on a 205?
Results 1 to 17 of 17
Thread: ABS on a 205?
    181
    ABS on a 205?
    Looking at a 205 sales brochure recently from the UK and apparently the later models (I'm assuming series 3) had the option of 2-sensor ABS. Does anyone know if we had this option in Australia, and anything more about it?
    XTC
    XTC is offline
    Mar 2003
    Location Location Location
    8,566
    Bagel:
    All the 205's I've seen have drums in the rear, I'd assume you'd need discs for ABS to be effective.
    XTC206
    Now this is a .sig
    Apr 2002
    London
    1,979
    I don't know from a mechanical perspective, but I'm sure I've read reviews of cars with rear drums and ABS. Maybe the ABS was for the front wheels? Am I completely of the track?
    Tim
    2016 Lexus RX450h
    Sense Pug307's Avatar
    Australia
    4,355
    The current 5 door Clios in Australia have ABS - front discs & rear drums.
    Peugeot 307 XS 1.6
    Rendezvous Adelaide 2005
    Nov 2001
    1,640
    306's equipped with rear Bendix drums had ABS on the front brakes only, according to Haynes. I guess this may be the same system used on the UK 205's mentioned (and maybe the Cleos too) .
    Rod
    <small>[ 26 June 2003, 12:35 PM: Message edited by: Rod Hagen ]</small>
    Rod's Home Page
    Rod's car page
    Fellow Frogger! DTwo's Avatar
    Melbourne, Victoria, Australia
    770
    XTC206:
    Bagel:
    XTC206
    Australian Series 3s and classics had rear discs
    We never had the ABS option here.....
    181
    Thanks DTwo, that's what I thought. If you happen to look at this thread again - what was upgraded/changed on the GTi from series 2 to 3 and Classics? Also, how do you tell series 3 and classics apart from series 2?
    770
    Bagel:
    I did a bit of a list in this post last year....
    <a href="http://www.aussiefrogs.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=3;t=000755" target="_blank">"Parry" 205GTI Information </a>
    The short answer is,
    S3s had pwr steering, 90kw engine, slightly different gearing, 15" speedline wheels, rear discs and they are 1991'+
    <small>[ 26 June 2003, 04:17 PM: Message edited by: DTwo ]</small>
    Mar 2003
    Tasmania
    1,419
    There is nothing to stop an ABS system being used on drum brakes. Think about it, ABS symply uses a sensor to detect when the wheel is locked, and releases the hydraulic pressure until the wheel starts to turn again. It can be applied to drums just as easily as discs.
    Pugs Rule!
    403, now sold
    404, project
    XTC
    XTC is offline
    Mar 2003
    8,566
    Pugnut403:
    Do drums react as well as discs with ABS? or is it a fallacy ?
    XTC206
    Now this is a .sig
    May 2001
    Sydney, NSW, Australia
    3,635
    My sister's Clio (disc front drum rear) pulls up SO hard once the emergency braking override system cuts in (I can't remember the acronym for it). I'd say it has better brakes than my XSi in terms of both progressive feel and then when you really hit them hard, the sheer power.
    I've never actually looked at the C3's brakes, but being a Citroen one would assume it has discs on the rear. I'll check it out wink
    Derek
    Nov 2001
    1,640
    Pugnut403:
    Probably not in theory at least, 403, but drums are usually fitted as a lower cost option. Probably wouldn't make sense to fit cheap brakes and then a high cost add on.
    Ther might also be some technical issues relating to the speed of reaction of the mechanism. Drums rely to some extent on the operation of a lever (one end of the shoe is pivotted). The linings are usually a little further from the drum than a pad is from a disk too.This probably means a longer travel time for the application of the requisite force. I would guess that it is harder to get the almost instantaneous application and release necessary for abs operation.
    As far as I know the rear drum brake cars on the market at present with ABS only have it on the front wheels.
    Rod
    Rod's Home Page
    Rod's car page
    XTC
    XTC is offline
    Mar 2003
    8,566
    Rod Hagen:
    As far as I know the rear drum brake cars on the market at present with ABS only have it on the front wheels. Cheers Rod
    Intersting ... does that mean you could still lock the rears up question
    XTC206
    Now this is a .sig
    Mar 2003
    Tasmania
    1,419
    A good driver can still modulate the pedal an a drum braked car, so I don't see how a computer would have any trouble doing it.
    If you only had ABS on the front, you should still be able to lock the rears up, which is a dangerous situation.
    Pugs Rule!
    403, now sold
    404, project
    Apr 2002
    London
    1,979
    I remember pressing the button at a pedestrian crossing once, and a women driving a magna decided to stop when the light went orange, she really should have just gone through, But:
    She slammed on the brakes, the fronts clearly had ABS working and did'nt slide at all, the rears were scretching and smoking like an errant teenager.
    Very dramatic... made me feel bad for her rear tyers!
    Tim
    2016 Lexus RX450h
    1000+ Posts brenno's Avatar
    1,937
    Rod Hagen:
    When you ordered an early 306 with ABS in Australia, it came with rear discs instead of drums.
    XTC
    XTC is offline
    Mar 2003
    8,566
    Pugnut403:
    That's what I'm saying ... not a very safe situation.
    XTC206
    Now this is a .sig
