Rolling guards on 306
Results 1 to 21 of 21
    392
    Just wondering if any one has had there guards rolled, my bak tyres start rubbing once i have four people in the car.
    Fellow Frogger! PULS8R's Avatar
    Nov 2002
    Melbourne, VIC, Australia
    199
    I don't know why you'd need to roll them unless you're tyres were very wide, or you had the wrong offset on your wheels. I'd get the offset checked out.
    How low is your car?
    But on the subject of rolling your guards, you can do it yourself if you like, or take it to a panel beater that will do it for you. You''re looking at about $25 per guard, depending where you get it done. Some suspension/tyre fitting places also do it.
    1995 306 XR
    392
    Running 205/45/16 only have a problem when have a load in the back, there is no problem with the front
    Fellow Frogger! jfn180's Avatar
    725
    thats wats happen to me since i put my new wheels and tyers on my 306,everytime i have 2 people in the back the wheels rub,but i just found out that my tyers are too wide there 205/55/15
    97`black 306 style sold JFN 306
    04 Black 206 GTI 180 JFN 180 FOR SALE
    I HATE V8 LANDCRUISERS
    WEST TIGERS= PREMIERS 05
    melb
    4,379
    Same problem with me, more than two in the back and the car scrapes
    392
    205/55/15 is to big of a tire if u want to run 205' run 205/45/15 or if u can get 205/40/15
    Fellow Frogger! Reno's Avatar
    1,260
    i run 215/40's get abit of scraping, need step into a 205/40, should solve my probs. the hardest thing is finding a tyre with the correct load rating 0f 85> for a 205/40 17"
    the guys @ quickfit tyres Newmarket did my guard rolling. speak to Jason there.... 3856 0098 tell them Julian sent you..
    XTC
    XTC is offline
    Mar 2003
    Location Location Location
    8,566
    immy s16:
    There is a BIG size diff with these tyres - up to 10% ... not good.
    <table border="1" width="100%" cellpadding="2" cellspacing="2">
    <tr>
    <td>Specification</td>
    <td>Sidewall</td>
    <td>Radius</td>
    <td>Diameter</td>
    <td>Circumference</td>
    <td>Revs/km</td>
    <td>Difference</td>
    </tr>
    <tr>
    <td>205/55-15</td>
    <td>113mm</td>
    <td>303mm</td>
    <td>606mm</td>
    <td>1905mm</td>
    <td>525</td>
    <td>0.00%</td>
    </tr>
    <tr>
    <td>205/45-15</td>
    <td>92mm</td>
    <td>283mm</td>
    <td>566mm</td>
    <td>1777mm</td>
    <td>563</td>
    <td>-6.80%</td>
    </tr>
    <tr>
    <td>205/40-15</td>
    <td>82mm</td>
    <td>272mm</td>
    <td>545mm</td>
    <td>1712mm</td>
    <td>584</td>
    <td>-10.10%</td>
    </tr>
    </table>
    - XTC206 -
    PS: Does anyone know why this table has so many line feeds before it (the big white space) I can't work it out
    Edit - make that "green" space ... HTML guru's Help ? What am I doing wrong ?
    <small>[ 11 August 2003, 06:34 PM: Message edited by: XTC206 ]</small>
    Now this is a .sig
    May 2001
    Sydney, NSW, Australia
    3,634
    I think with the 306 you can make *anything* scrape if you try.
    I'll just say this. After the Melbourne drive, I took off the back wheels. There were huge rub marks on the plastic guard lining. I know they weren't there before the drive. I guess it all depends how fast you are cornering. That had 175/65R14's on it (I think)
    I get the feeling from this thread that you shouldn't go wider than 195 though?
    Derek
    melb
    4,379
    DeKa:
    Derek
    O NO!! Thats no good by the sounds of things a few of us have 205/45+.
    What are our options?
    1000+ Posts brenno's Avatar
    1,937
    immy s16:
    Huh?
    205/50 15 is much more popular than any of the sizes you suggested, and are bang on the rolling diameter of 195/55 15 and similar to 185/65 14 as well.
    392
    Yeh Im running 205/45/16 but diffnetly will not go any wider there is only about 4mm clearance from the tyre to the bump stop to the right of tyre's on the back, the front has heaps of room.
    But i think my prob is that the negative camber is making run on the inside wall of the tyre, which is only a problem with a full load so from now on 3 max in the car.
    Fellow Frogger! WRCPUG's Avatar
    May 2002
    Glen Iris, Melbourne
    1,035
    I got my front guards rolled bout 6 months ago.
    I have 17" rims with 205/40/ZR17 tyres and i USED to not rub the rear. I had lowered the rear alot too. I once had 3 ppl in the back 1 in the front and 1 in the boot and i still dont think it rubbed???
    It was pretty funny i though the car was gonna fall apart
    Now with my GTi6 rear end i Rub the rears when i go over bumps It suks i havent had anyone in back nor do i want to.....ASAP i will go get the rear rolled/lipped to remedy the problem
    PEUGEOT 306 GTi6 (1997-1999 HYBRID)
    105.4kw (141HP) ATW
    2:09 Phillip Island (Toyo Street Tyres)
    2001 YAMAHA YZF-R6
    119HP
    1993 MITSUBISHI 3000GT Twin Turbo
    300BHP
    STOCK-14.006 @97.4mph HEATHCOTE
    STOCK-1:15 CALDER Long Circuit (Stock Street Tyres + Stock Pads :banghead )
    (For Sale)
    Oct 2002
    Western Australia
    20
    Unfortuneatly my 306 sedan does the same.
    Does anyone know a suitable person/company in WA who will carry out the procedure properly question ie. roll not panel beat.
    cheers!
    Steve
    Oct 2002
    Western Australia
    20
    cheers!
    Steve
    XTC
    XTC is offline
    Mar 2003
    8,566
    Pugsley72:
    Unfortuneatly my 306 sedan does the same. Does anyone know a suitable person/company in WA who will carry out the procedure properly question ie. roll not panel beat.
    cheers! Steve
    I can't advise, sorry. You have to watch the roll job though .. seen panels end up with creases because someone didn't know what they were doing ... not pretty.
    Coming to the Inaugural WA AussieFrog cruise Steve ? Don't tell me you missed all the advertising
    - XTC206 -
    Now this is a .sig
    Oct 2002
    Western Australia
    20
    XTC206.
    Thanks for the warning, I knew there is a chance of creasing I was going to check out the standard of work before considering, as I rarely carry four in the Pug anyway
    Count me in for the cruise will not miss this one
    cheers! I have not missed all the advertising I just had to rearrange my schedule. head_ban
    Steve
    392
    Xsara how much did they charge you rolling your gaurds? and also are you happy with the work they carried out, cus i am on the S Side and wouldnt mind driving up to the north if its worth it
    May 2002
    1,035
    If you were in Mebourne i could tell u the place i got mine done.
    The guy that did mine actually patented the machine that does guard rolling. He did a very good job i got my springs reset and guards rolled(for the front) for $220
    105.4kw (141HP) ATW
    2001 YAMAHA YZF-R6
    119HP
    300BHP
    (For Sale)
    1000+ Posts CHRI'S16's Avatar
    Jun 2002
    3,298
    Im running 205/50/15 semi-race ruber (big really!) all round, and i have put my car on several NSW tracks, several times, and also run, 17" wheels with 205/40/17 rubber. I have yet to hear a guard scrape..... sorry can't help guys.-chris
    ... ptui!
    1,260
    immy s16:
    they did good work... not exceptional but definatly above par.
    cos i can remember. was about $120-150 for all 4. or osmeone in that ballpark.
