Extra Washers on front sway bar mount 504
Results 1 to 12 of 12
    1000+ Posts Shobbz's Avatar
    Brisbane, Australia
    1,284
    When I was at the French Car day here in brisbane I was talking to a 504 owner who had put extra washers on the front suports for the front sway bar. The two nuts at the very front of the car.
    There is a bit of space there and it seems like a good idea?
    Has anyone done this?
    thanks
    James
    Previous
    2005 407 ST Exec
    1975 504 GL
    9,223
    I think you mean the radius arms or the caster arms. The sway bar has no locating function in the suspension.
    The rubbers should be all that are needed, but they do chop out. I've had one with a hefty rubber washer in it, but I wouldn't think you could do better than just putting a new rubber in there.
    For some reason it's said that the 505 rubbers are an improvement on the 504 ones. They don't cost much at places like Import Advantage (Stafford).
    Brisbane, Australia
    1,284
    Sounds like a more reasonable part description.
    The rubbers look okay, but there is a lot of distance between the metal and the nuts.
    Will investigate this place u speak of
    Import Advantage? They do Pug Parts? Or just rubbers?
    Previous
    2005 407 ST Exec
    1975 504 GL
    9,223
    Pug parts...
    They're importers of a wide range of parts, Peugeot is almost an orphan but they have it. They love BMWs and VWs... you get parts there, nothing in the way of information or advice, at least with Pugs.
    In Webster Road near the traffic lights north of the bridge that crosses the creek there. You park up on the footpath, or beyond the footpath, the building is back a bit from the road.
    Brisbane, Australia
    1,284
    Can't hurt to swing by and have a look
    thanks
    James
    Previous
    2005 407 ST Exec
    1975 504 GL
    Dec 2002
    CANBERRA
    400
    Hi, before the 505 style rubber was available we used to put big washers on the rally car. This pulled on a bit more angle on the strut (forward) and reduced the amount the strut moves back and forth in put holes etc.
    Since the 505 style rubbers became available I have not thought this necessary. When in good condition the extra rubber behind the washer on the 505 style serves much the same purpose without being rigid.
    Jim
    Guru davemcbean's Avatar
    Apr 2001
    Camden NSW & Selwyn NZ
    2,334
    Yeah, as Jim indicated the 505 ones are a big improvement. I don't know why alot of places still bother stocking the older type.
    Dave
    NZ Fleet
    1976 504 Ti
    1984 205 GT twin carb
    1991 205 SI 1.6GTI motor
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    Brisbane, Australia
    1,284
    I had a good look under the car today.
    There are three rubbers I want to replace. I have allready bought one set.
    I am replacing the verticle rods with washers at the ends that attach to the sway bar? Its the sway bar right? Mine have V shaped bits on them apparently for the power stering version, which i may have to chop off.
    There are two big rubbers that also are on the sway bar (sorry if this is not what its called, little lost here) that are held in place by two vertical bolts.
    Then there are two rubbers at the front of the car, one on each side that are held in place by horisontal bolts?
    I want to replace them all, hopefully they don't cost that much?
    Does everyone follow the rubbers I am describing. Sorry I work on physical items not their technical names. If some one can convert my rendom descriptions into technical/ correct terms it would be appreciated.
    Its been long journey, but the pug will ride again.
    thanks again
    James
    <small>[ 10 August 2003, 01:13 AM: Message edited by: Shobbz ]</small>
    Previous
    2005 407 ST Exec
    1975 504 GL
    9,223
    Shobbzy... I'll be in Brisbane next week and would be happy to have a look at your car for you.
    Advice free... but coffee would be nice.
    Brisbane, Australia
    1,284
    A look at an old heap?
    Coffe, that's the black stuff with milk right?
    When are you in town?
    Uni permitting would be nice.
    thanks
    James
    Previous
    2005 407 ST Exec
    1975 504 GL
    9,223
    All next week...
    Give me a call on 0411 280 267 some time this week and we'll arrange something.
    Brisbane, Australia
    1,284
    Cool,
    Will see how things are next week and give you a call.
    thanks
    James
    Previous
    2005 407 ST Exec
    1975 504 GL
