Fluttery Noise
Results 1 to 8 of 8
Thread: Fluttery Noise
    Jan 2002
    S.E Melbourne, Australia
    262
    Fluttery Noise
    Ever since i got my 505, there has been a "fluttering" sorta noise that seems to come from the exhaust manifold side of the engine.
    It's more obvius when the engine is cold, but other than an annoying noise, the engine runs well.
    The Exhaust pipes and mufflers were replaced and the exahaust manifold was inspected recently by Bob Watson Service Centre, (by previous owner) and no problems were found.
    Idea??
    Jason Judd
    <img border="0" alt="[Peugeot Emblem]" title="" src="graemlins/peugeot.gif" /> '85 505 GTi Executive
    <img border="0" alt="[Peugeot Emblem]" title="" src="graemlins/peugeot.gif" /> '88 205 GL 1.1
    8,218
    Jason,
    My guess is a leak at the exhaust manifold, check to see if your manifold bolts are done up tightly when the engine is cold.
    As the manifold warms up exhaust leaks close off with the expansion, hense you are only hearing it when engine is cold.
    08 C5 X7 HDi very Noir
    Jan 2002
    262
    Well, thats what i thought at first. I'll have another look in the daylight tommorow. Still...
    I dont think it is the manifold, judging by the volume of the sound...
    Jason Judd
    Nov 2001
    1,640
    Sounds like an exhaust manifold or flange gasket to me too.
    Another possibility is a hairline crack in the manifold or the downpipe flange welds (505's are rather prone to this and replacements can be expensive).
    Check the tension on all the relevant studs (head to manifold and manifold to downpipe) with the engine cold , but don't put herculean pressure on the wrench. You can sheer off the studs or crack the manifold if you aren't careful.
    You can often 'feel" a leak on you hand, but don't get burnt! These bits gets hellishly hot.
    Rod
    Rod's Home Page
    Rod's car page
    Jan 2002
    262
    Well, i'm gonna go out now and have a look....
    Jason Judd
    Jan 2002
    262
    Tis without a doubt the Exhaust manifold, were it is bolted to the engine. At the top end i would say.
    Problem is i wouldnt have a clue what to do about it
    Jason Judd
    Nov 2001
    1,640
    First try simply tightening the nuts Jason (with the engine cold) . If this doesn't fix the problem its a matter of removing the manifold and replacing the cylinder head to manifold gaskets. This is fiddly, but not difficult.
    Its a good idea to fix it, because you increase the risk of having the manifold crack due to uneven tension if one gasket is disintegrating. It can also affect performance to some extent, because of its effect on the readings from the O2 sensor etc.
    Rod
    Rod's Home Page
    Rod's car page
    Jan 2002
    262
    Just an update:
    Yesterday, i took out the aicleaner, and had a closer look at the manifold. Many of the bolts were finger-tigh, and one of the studs from the head was missing altoghthere.
    I tightened all the bolts, and removed the EGR valve to tighten the bolts underneath. I also found the EGR valve (which was always very noisy) was not working, so i made a gasket to block it off
    Anyway... Put it all back together, and now i have a car that is far quieter, smoother and pulls away from the lights faster
    Jason Judd
