Weird Wires
Results 1 to 10 of 10
Thread: Weird Wires
    Fellow Frogger! MR206's Avatar
    Apr 2002
    Sydney Australia
    331
    Weird Wires
    when i was cleaning my car the other day, i looked under the drivers seat in my 206 and noticed wires which should be connected to something, The wire has a plastic head which is meant to go into a port, but im not sure wat its for
    anyone got similar wires under there seat or hav an idea wat its for?
    2002 China Blue Peugeot XT
    Canberra Raiders #1 Season Ticket Holder
    Sense Pug307's Avatar
    Australia
    4,355
    If it's under the driver's seat, it might have something to do with side impact airbags.
    It's probably a provision for that feature, which isn't standard on your car.
    Just a guess.
    Justin
    Peugeot 307 XS 1.6
    Rendezvous Adelaide 2005
    6,543
    Maybe it's set up for a CD stacker?
    Stuey
    2003 PEUGEOT 206 GTi
    12,269
    that's ok
    i have wires under mine as well but they are connected
    but i have somw under the passenger side that aren't
    i've never worried about them
    behind the dash of a 604 are a few plugs that look like they should go places as well but they just sit in the middle of nowhere and do nothing
    the wires may be for heated seats
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Apr 2002
    Sydney Australia
    331
    heated seats? i like da sound of dat lol full mad in da winter
    May 2001
    Sydney, NSW, Australia
    3,635
    I'd imagine it's something to do with the pressure sensor used to detect if you're in the seat or not.
    If you're in the seat and the seatbelt isn't on, the seatbelt light lights up on the dash correct?
    If there's no one in the seat and the seatbelt isn't done up the light doesn't come on.
    I'm not 100% sure on the 206 cos I've never looked but that's my guess
    Derek.
    2000+ Brad's Avatar
    2,404
    I would say only 75% of the wiring loom in my S16 is connected to anything worthwhile. I think PSA use the same wiring looms for many different cars to cut costs.
    12,269
    the seat belt light comes on in the 306 wether you are in the seat or not with the engine running
    the only time it goes off is when you put the belt on so i'd say the switch for that is in the belt thingy
    heated seats were an option in 306's but not out here as far as i know
    i think some 405's had them though and the 607 will probably have them
    not sure about the 406's but the coupe may have them
    1 x 2018 3008
    Australia
    4,355
    I doubt it's the seatbelt sensor, as the seatbelt light only works on the drivers seat in the 307.
    Does Peugeot have any seat occupancy sensors? I've seen it in the current Toyota Corolla to (de)activate the passenger airbag.
    Justin
    Peugeot 307 XS 1.6
    1000+ Posts pgti6's Avatar
    May 2001
    1,625
    Had a similar problem on my GTi6 a while back.
    I'd also given the interior a good cleanout, moved the seats fully forward etc,etc & on completion found the airbag warning light came on & stayed on.
    Turned out to be the wiring to the seatbelt sensor which was so short that moving the seat fully forward had partially disconected the plug under the seat.
    The dealer knew of the problem & had a 'fix' (free) which was a small plastic saddle which held the connector together.
    Talk to your dealer-he may know of something similar which activates the seatbelt warning light
    Good Luck
    Jeff
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
