Ticking from my 205
Results 1 to 13 of 13
    May 2002
    21
    Ticking from my 205
    Hi
    I have a 89 205 gti 1.9.
    When i accelerate i have a ticking noise coming from the engine, before you can only hear the ticking noise at high revs.. but now it will just keep ticking and ticking and ticking when i'm driving and the acceleration isn't as strong as before ...
    I believe it is going to die soon .. there is no smoke coming out of the exhaust tho! i don't know what it is.. can anyone help??
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    Melbourne, Australia
    2,930
    Tappets / Valve clearances?
    How many kms has your 205 done?
    Nick
    1983 Peugeot 505 GR
    May 2002
    21
    It has 179 kms
    Jun 2002
    brisbane
    45
    G'day.
    Ticking sounds from an engine can be simple faults like a crack in an exhaust manifold or a leaking flange on the exhaust or lack of engine oil,pinging or bearing failure in altenator,water pump or idler bearing's,get a mechanic to look at it quick.
    Chuck.
    May 2002
    North Ryde
    83
    Get it checked asap...when was the last cam belt replaced? mallet could be water pump or cambelt tensioner. Check oil and coolant levels. Engine noise will increase if either are low....even if not down to a critical level yet. Rock on head_ban
    Peugeot 306 GTi6
    Peugeot 205 GTiS2, you want it? call me 0414 996 499,
    May 2002
    21
    Thanks!
    I took it to a mechanic and they fixed the problem i was having. But it is now back to the stage where at high revs it will have this pinging noise.. it is so annoying and it really affects the performance..
    Does anyone know what this pinging noise is?
    May 2002
    21
    Oh, i don't know when the last cambelt was changed. I got the 205 around 2 months ago and i havin't really changed anything, i believe i will need to get the engine seriously looked at.
    Apr 2002
    120
    What type of fuel are you using?
    I have an 88 205gti that always like to drink the expensive stuff - it pings alot if I use regular unleaded.
    May 2002
    21
    I just use regular unleaded... premium is abit too pricy! and it doesn't look attractive .. so i guess if i want no pings.. i should use premium?
    Apr 2002
    Tasmania
    112
    from my knowledge of high performance french cars it is almost imperative you use premium or better still optimax if available i'm in tassie and unfortunately we can't get optimax but i put standard unleaded in my axgt and it didn't like it much at all
    try premium for a couple of tanks and see how you
    Hobart
    1,496
    I have an 89 405 Mi16 and have found it makes little difference !
    1989 Peugeot 405 Mi16
    2000 Peugeot 306 XSI
    1973 Peugeot 504 GL
    May 2002
    North Ryde
    83
    You have two choices, you can run standard fuel and retard the timing by a few degrees which will basically render the engine a slug,,,,,or you can run the good stuff. I have found Mobil 8000 to be better than Optimax.....sometimes pinging on Optimax. Make sure you find a good fuel station and stick to it. There are some really crappy fuel stations out there. I filled up with high octane ULP at the mobil on Oxford St Paddington, I pulled out onto the street and the car started stalling and lost all it's power. Bang some ocatne boost in and it ran a little better. In short, don't compromise your bang juice!!!! head_ban
    If you're short for bucks, at least alternate Hi to Low octane. <a href="mailto:[email protected]" target="_blank">[email protected]</a>
    Peugeot 306 GTi6
    May 2002
    21
    Hi thanks for everyones advice, anyways i just started using Mobil 8000 and what do you know! i can tell that it is running better then before. The pings aren't as loud as before.. sounds like they are slowly going away?!?!
