Central Locking Actuator
Results 1 to 8 of 8
    Aug 2003
    2
    Anyone know of an aftermarket central locking actuator that will fit a Pug 205 gti? Not wanting to spend $150 on the genuine article which is a back order from France!
    1000+ Posts CHRI'S16's Avatar
    Jun 2002
    3,298
    Dick-smith and Jaycar, also some discount stores sell complete aftermarket units which ive installed to great longterm use.
    Eg. my pearents Ford 4 years and still going, all the price of $45-$100 depending on when and were.-chris
    ... ptui!
    Mar 2003
    Tasmania
    1,419
    Wold it be hard to use one of those kits to replace the 604 vacuum central locking?
    Pugs Rule!
    403, now sold
    404, project
    Jun 2002
    3,298
    Pugnut403:
    Honestly ive never done a or seen a 604, but aslong as the action for the actual pin or internal dor lock is mechanical (ie-that is via the factory rods) then these kit can be adapted to fit almost any car. If good time and labour are spent whilst installing and feeding the cables through the doors/jambs et, then they prove very reliable. They can even be often adapted to a aftermarket Car alarm, with imobiliser circuits.... something to think about.--chris
    ... ptui!
    1000+ Posts Shobbz's Avatar
    Brisbane, Australia
    1,284
    So if the door is locked with a rod, the motor can retract the locking mechanism?
    Hmmmm interesting, I like.
    James
    Previous
    2005 407 ST Exec
    1975 504 GL
    Jun 2002
    3,298
    Shobbz:
    James
    Put simply, its yes to 99.9% of cars on the road today. Access can sometimes become an issue, but the same principles apply, a 12v eletronic 2-way actautor, drives a rod, which is mechanicaly connected to either the door lock or the pin rod of each door. One actuator for each door on a comon and supplied wiring loom controled by a master s/w box and operated via the master door/doors (usually the drivers door), or via remote control alarm, done.--chris
    ... ptui!
    Mar 2003
    Young
    121
    Yes they work like a charm on the 604 I've done a couple with very good results. It is even possible to make them remote locking while you are at it.
    Jun 2003
    Griffith
    43
    i had new central locking fitted into my car, it was a generic brand, and cost me 150 bucks, all up for them to do it, how ever, the rear drivers door, doesn't unlock at all, the motor goes in it and all, but no action :-( dont know how to fix that..
    so yes, a generic locking ssytem will work in your pug :-) mallet
