Cold air intake?
Results 1 to 14 of 14
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    Melbourne, Australia
    2,930
    Cold air intake?
    Some of my friends with Japanese cars are slightly obsessed with engine mods such as a cold air intake. I was thinking that the 505's air intake is really sitting right on top of the engine so it must be sucking in hot air.
    Has anyone ever bothered to try fitting some sort of cold air intake on a 504/505? I don't mean a K&N cone filter, just a pipe running from the front of the car up to the air filter housing. I was thinking the hot air box attachment would make it very easy to fit a hose to the filter housing.
    Is it worth trying this (or at least wait til summer ) or just let it be?
    This 505 (from Chile) seems to have a different air filter setup which takes the air from the front of the car:
    <img src="http://www.garage24.net/505ww/50542.jpg" alt=" - " />
    Nick
    1983 Peugeot 505 GR
    Gus
    Gus is offline
    Fellow Frogger! Gus's Avatar
    Jun 2002
    Canberra, Australia
    600
    The STIs had a cold air setup which sucked from above the radiator. The metal plate that sits between the radiator and the grille (across the top) has a hole in it, and a fitting mounted to take an air duct to the intake.
    I imagine you could find one of these plates quite easily from a wrecked STI, and with some flexible ducting plumb from the inlet to your air filter.
    I have on in my garage (holed plate & inlet fitting), and could mail it to you if you want (but I bet you could find one in Melb.)
    Alternatively, GTIs sucked cold air from the driver's side of the radiator, and on some cars (including my STI) there is still a second opening there (in front of the radiator, to the side) to which a duct could be attached. The Chilean car you picture looks like it might be using that inlet.
    Bear in mind your GR might actually have a heated inlet manifold, in which case cold air will do precious little good.
    181
    I thought about the same thing and was actually consider a K&N for my 504Ti. Seems that the intake is actually pretty good for the standard setup (oil bath filter type), all you need to do is change the oil in a normal service and clean it with petrol rather than buy a new filter cover each time. Plus the intake hose sits in front of the radiator. The only question I have is why is the mouth facing the side of the car instead of curving to the front. I guess you'd get a lot more crap in the filter and maybe more servicing needed but isn't that a pretty good price to pay for more air?
    It's also intersting to note that the rubber intake hose has a metal trumpet piece in the mouth for better flow. It's amazing they went to all that trouble for such a tiny curve radius - must make a lot of difference.
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    2,930
    Bagel, I don't have an oil bath filter. My car is pictured below (I appologise for how dusty it is in the pic, it had just been bush bashing!)
    <img src="http://groups.msn.com/_Secure/0QACvBHYSiEyn8xR3XlUWclmW26oFRdsfabFgRk01n1zPy1xuy 9vajpIxv95DZ*55IguaR5iZ7xzv7khcQlOkBKRcS8xfixEVqo6 vBBxw5w8/engine1.jpg" alt=" - " />
    Gus, I think you are right about it being heated. There is a smallish rubber hose running off those pulse air valves (?) to the back of the filter housing.
    <small>[ 15 June 2003, 06:16 PM: Message edited by: nJm ]</small>
    Nick
    1983 Peugeot 505 GR
    12,269
    nick
    is it just the pic or is that carby of yours very reddish in colour from petrol staining ???
    if so you have some major leakage in and around that carbie
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    2,930
    I've always wondered why it was red.
    Interesting.
    Nick
    1983 Peugeot 505 GR
    Hobart
    1,496
    Nick,
    Go down to your local auto parts shop and grab a can of Carbie Cleaner, take the air cleaner hose off and give all over the carbie a good go with it *including down the throats*
    Ben
    1989 Peugeot 405 Mi16
    2000 Peugeot 306 XSI
    1973 Peugeot 504 GL
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    2,930
    I'm sticking a newer carb on it this week so I think it will be ok
    I've never noticed a petrol smell so maybe it used to leak and was fixed up before I bought the car?
    Nick
    1983 Peugeot 505 GR
    Hobart
    1,496
    If I were you Nick, I'd give the new carbie a good clean up before u put it on, just for good measure...
    After all a can of Carbie Cleaner is only around $8!
    Ben
    1973 Peugeot 504 GL
    Nov 2001
    1,640
    504's with a similar airfilter set-up came fitted with an "automatic" cold / warm air "diverter valve" mounted on the front of the air filter body , Nick. Many people took them off because they rattled, and looking at the picture I find myself wondering whether yours might have originally had one too.
    Rod
    Rod's Home Page
    Rod's car page
    Guru davemcbean's Avatar
    Apr 2001
    Camden NSW & Selwyn NZ
    2,334
    pugrambo:
    nick
    If the carby has never been cleaned since new, then after 20 years it will be very dirty, regardless of how well it seals.
    You really need to clean the outside of them atleast once a year, just like the rest of the engine.
    Dave
    NZ Fleet
    1976 504 Ti
    1984 205 GT twin carb
    1991 205 SI 1.6GTI motor
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    2,930
    Well I have the 'new' one sitting on my desk at the moment. It is far less dirty than my old one, but still a bit grubby. Should I just spray some degreaser on it and give it a quick scrub? I guess I should make sure the degreaser can't get in any of the places were the numerous hoses connect .
    Nick
    1983 Peugeot 505 GR
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    2,930
    Rod Hagen:
    Rod
    Yes it did. The previous owners had taken it off. It is sitting in the garage somewhere...
    Nick
    1983 Peugeot 505 GR
    Apr 2001
    2,334
    nJm:
    Well I have the 'new' one sitting on my desk at the moment. It is far less dirty than my old one, but still a bit grubby. Should I just spray some degreaser on it and give it a quick scrub? .
    Just wipe the outside with a rag soaked with solvent (e.g. paint thinners, acetone, etc). Make sure you wear gloves. This brings the carby up like new.
    Dave
    NZ Fleet
    1976 504 Ti
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
