505 STI wheels again!
Results 1 to 15 of 15
    9,276
    I have just bought a very clean STI for $1000 (at a Citroen dealer where I was looking to defect to a BX, very interesting seeing the horizon rush toward you in the 16 valve.)
    Of course it has the metric rims. There was talk of turning them down to 15 inch, has anyone actually done this yet?
    This car may be a basis for a Holden V6 conversion in the future.
    Graham Wallis
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,772
    Holden V6 conversion?????? Wash your mouth out! I drive Conformadores for work - the V6 is a truly detestible piece of ancient history.
    12,269
    graham
    have you got any 15" STI/TRX wheels ?
    if you have measure the rim lips on both and the internal diameters and see how much difference there is between them
    also measure the dia of the safety lip as well
    you will find the outcome very interesting
    then go and see your local machine shop and give them the dimensions you desire on the metric wheels
    you will find that there is very little machining to be done
    when you get the measurements post them on here as i can'r remember the difference between the two wheels but i do recall it is very little
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Gus
    Gus is offline
    Fellow Frogger! Gus's Avatar
    Jun 2002
    Canberra, Australia
    600
    As I understand it the other problem with these wheels is they are soft, so if you take them offroad (or maybe through a couple of potholes) they'll warp very quickly.
    Can anyone confirm or deny this? How bad is it? (I've got 3 of these wheels with good tyres and I'm thinking maybe I'll go and find 2 more when my steelies need new tyres. But I live in the country...)
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    Melbourne, Australia
    2,930
    I'll be interested to see what happens. I need new tyres for my 505 which is currently sitting on its original 5x14" steelies and running Michelin MXTE 180/85's.
    I'm looking for at best 15" wheels off a GTi (steel or alloy, doesn't matter), or if not something like the 14" Amil wheels.
    Would changing from 14" to 15" alter my speedo too much? I assume if I had pug 15" wheels I'd be best with 195/60's?
    Nick
    1983 Peugeot 505 GR
    Jan 2002
    Canberra, Australia
    97
    In Reply to:
    I have just bought a very clean STI for $1000 Of course it has the metric rims. There was talk of turning them down to 15 inch, has anyone actually done this yet?
    A big slap in the face for wanting a holden pug mallet
    Seriously, a Holden! mallet
    JoFuS
    9,276
    I drove Commodores for work and they went like stink with excellent fuel economy. Trouble is they didn't steer, rode badly and up until the VT had no style!
    My rally 505 2850 even fire goes nearly as well but uses more fuel.
    Actually, this might not be neccessary as I am replacing the fuel injection with a suitably modified Fuego manifold and Weber DCD carby. Should be very interesting, hopefully it will be done by next week and then we will know if the engine or the injection system is the limiting factor in the STIs performance.
    I will have a good look at the rims after the carby conversion, my 14 inch cheviots will do until then.
    Graham Wallis
    Fellow Frogger! PCOATES505's Avatar
    Jun 2002
    Gunbower
    388
    Graham,
    I asked the guys at ajax wheel works about turning down the trx wheels and they said they had tried it, but found that the wheels are a very soft alloy, and when they tried to fit the tyre the lip of the wheel rim broke---not good news regards pete
    I am gunna get another 403 on the road........one day
    Jan 2002
    Canberra, Australia
    97
    hmmmm.... that would be bad. Does anyone know of someone who has had it done successfully?
    Graham:
    It's still a holden mallet
    JoFuS
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    2,930
    Well, I've rung PugWreck in Vic, and they put me on a waiting list for either SR 5.5x14" steelies ($49.50 each) or Cheviot 14" alloys for about $440 for a set.
    She told me that really it will be a while with all these STi owners wanting new wheels blush evil
    Nick
    1983 Peugeot 505 GR
    May 2002
    canberra...
    8,772
    What about 504 wheels and get wider rims fitted, or 604 wheels?
    12,269
    there used to be a bloke in VIC but i can't remember his name that used to turn the wheels down to suit the 15" tyres
    i have seen a few sets that have been done and if they are done right they are no softer than what they were before hand but they are a very soft wheel to start with
    they are also a very light wheel which on normal roads is a good thing and even better if you are doing some track work as you reduce your unsprung weight by using these wheels
    do you know if when they did this that they might have skimmed the lip of the rim at all or even undercut the lip ?
    i did one as a trial a few years ago and ran it on the car for quite a while and never had any trouble with it
    (i needed one as i had a bent one and this was all i had sitting at home )
    but for the life of me i can't remember how much i had to remove hence the need to measure and compare the differences between the two wheels
    i do know that it wasn't much at all the needed to be done
    as far as i know that wheel i turned down is still running on the car but as i said it was a one off that i did but i have seen a few other sets that have been done without any trouble
    1 x 2018 3008
    Jun 2002
    396
    GRAHAM WALLIS:
    Graham,
    Sounds like a good idea. Let us know how it goes. I think you're right, the standard FI system is the limiting factor, because those mechanical airflow meters must be a large cause of high rpm restriction.
    Are you just cutting and rewelding the Feugo manifold to give it the correct angle?
    Are you using a 28/36DCD, or a 36DCD? I've never been able to solve the right hand corner high
    G-force fuel starvation problem with the DCDs, but it usually only occurs when you're pushing really hard. The Cortina GT's were lucky that Bathurst is an anti-clockwise track. The DGV and the DFV don't suffer from the same problem, probably because their jets are in the centre of the fuel bowl, instead of the corners.
    Dave
    9,276
    Dave,
    We are using spacer blocks machined at suitable angles.
    The carby is a 36DCD which I last used on a 404 rally car, no problems with surging. It has 28 and 29 mm venturis so should be big enough for the 2.2.
    Graham
    Jun 2002
    396
    GRAHAM WALLIS:
    Yeah, it should be big enough. The 36DCD I had on my 2 litre 504, and my father's before that, has 27mm venturis, and I remember my father doing around 7500rpm on a number of occasions, without it running out of breath, so I guess the 28 and 29mm venturis should suit the 2.2 litre well.
    Dave
