Rear Engine Seal Leak
    Jan 2005
    Mudgee NSW AU
    3
    Default Rear Engine Seal Leak
    Hello All
    My XD2 diesel has developed a BAD oil leak (literally 5 litres in 50kms!), seems to be at the rear of the engine where it mates the gbox. I suspect it is the rear crank seal.
    Can the seal be replaced with out removing the crank? as it is in two halves?
    Anyone shed some light on this?
    If the crank has to come out what else should be replaced?
    Steve
    May 2004
    United Kingdom
    338
    You can change the rear main oil seal without removing the crank, Its a gearbox & flywheel off job though.
    Then while its in bits you might as well stick a new 3 part clutch assy in.
    If its an XU engine, It could also be the 2 hockey stick oil seals under the main crank bearing cap directly behind the flywheel, Thats a sump off job to do.
    2003 Pug 206 GLX TU3JP
    Jan 2005
    Mudgee NSW AU
    3
    What do you call a XU engine?
    Three piece clutch kit? Basically the whole clutch assy?
    thanks
    May 2004
    United Kingdom
    338
    Hi what Pug have you got?
    An XUD is the 1.8 or 1.9 diesel or turbo diesel engine fitted to 205s, 309s, most diesel 306s, 405s, Most of the 406 diesels.
    Yes I do mean the whole clutch assy, If your taken the gearbox out to change the seal behind the flywheel, It would make good sense to stick a new clutch in at the same time.
    12,269
    XD2 is the 505 diesel engine
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Jan 2005
    Mudgee NSW AU
    3
    Default 504
    Thanks, I see the logic in replacing the clutch.
    The XD2 is out of 504 sedan, although I have it in my 504 famil wagon, along with it's matching gearbox. It is not a turbo.
    Looks like I better start ordering seals and clutch kits.
