I'm tryng to solve a mystery of an oil leak on my car.
When it was rebuilt 18 months ago, the previous owner was told that there was a leak from the rear end of the crank. The mechanic had not worked on Pugs before and was not that familiar with the slinger. He said that the leak only really happened after the engine was stopped, but none was apparent when the engine was running. Obviously because it was being slung back into the crankcase. He spoke to some Peugeot mechanics who told him that it sounded like the crankshaft needed replacing.
Now, everyone I've spoken to about this that knows Pugs finds this scenario hard to believe, that it is almost unheard of Pugs leaking from the rear end. I'm also not too sure about the not leaking when it's running thought either, judging by the amount of oil caked onto the gearbox and surrounds. It seems that at the moment the oil consumption is a bit high - I think around a litre per 1000kms - but this may be due to the hotter weather and longer runs the car is doing thining the oil more than normal (I am running 20W50).
Being unfamiliar with the crankshaft setup, with the photos in Haynes not being much help, has anyone got any photos of crankshafts or could give a description of how the system operates.
Any other ideas on where the oil could be coming from would help also. The car does not seem to leak when stationary for a while, but it does drip as soon as it is stopped, although this is probably just be the oil that has been flung around under the car. I've had a look around and had no luck finding anything obvious.
Matt
