Draining engine coolant
Results 1 to 8 of 8
    Feb 2001
    493
    Hello all,
    Where is the plug to drain the engine coolant from the cylinder block? The one on the radiator is easy enough to find but i can't find the engine plug.
    8,205
    Pugsly,
    On which engine?
    08 C5 X7 HDi very Noir
    Feb 2001
    493
    oops! 98 306 Xsi, that's the 2L 16v
    thanks
    8,205
    Pugsly,
    I'm sure there are members on this board that can help you, the latest pug I've owned was a 505 so I'm of no use. Now if it was a 203 it would have been so easy, just a sprung lever on the side of the block
    Nov 2001
    1,640
    Same spring approach on the 403 too. The plugs had a nasty habit of corroding away after a time though. Remember seeing a few where you almost had to drill through the accumulated junk in the water jacket at the plug hole to get anything to come out of them!
    Rod
    Rod's Home Page
    Rod's car page
    9,223
    From memory the spring-lever retained plug was used up until 1966 in the 404. Maybe only 1965, though... been a long time since I played that game...
    And yes, often you'd get them free and spend the next hour coaxing a trickle through the accumulated rust and junk.
    Apr 2001
    Sydney, Australia
    64
    On the 205 it is on the back of the water pump, between the engine and the firewall. cant say about the 306 tho. dammit. i want one
    Fellow Frogger! Mi16 Man's Avatar
    Canberra, ACT
    711
    Hope I am not too late!!!
    As the 306 2.0L is a XU10J4 engine like my Mi16, the plug is at the back of the block, low down near where the driveshaft comes out of the diff.
    It is from memory around a 15mm nut.
    Quote from Haynes Manual;
    "On 2.0L engines, the drain plug is located at the rear left hand end of the cylinder block, next to the rear engine mountings."
    Happy flushing!
    Stu
    "Take a Lion through a corner - FAST"
    Current Fleet;
    2010 308 XSE HDi SW [Vapour Grey]
    2010 VW GOLF GTI [Carbon Steel Grey]
    In the Family;
    2012 508 Allure HDi [Thorium Grey]
    2008 207 HDi XT [Bianca White]
    Past "Frogs"
    2008 308 XSE HDi SW / 2006 307 XSE HDi Touring / 2001 306 XSi / 2005 206 GTi180 / 2005 407 HDi / 2003 206 XT / 1993 SII 405 Mi16 / 1990 205 GTi / 2x 1985 505 GTi S1 / 1976 504 / 1982 20 TS / 1997 306 XR / 1992 205 Si
