1981 505sr - lead replacement / premium?
Results 1 to 9 of 9
    Jan 2005
    1
    Default 1981 505sr - lead replacement / premium?
    Just not sure what petrol i should continue using for my old 350k 505, Lead replacement, unleaded or Premium. I think the lead replacement is killing it. Spark plugs or grimed up last service and sound real rough on unleaded. Premium is expensive too. can I win in this situation??? cheers..
    Dec 2002
    CANBERRA
    400
    Run it on premium and it will purr. The difference in cost between premium and ordinary unleaded should be compensated for by improved economy, and smoother running.
    12,269
    you can always try water injection at the same time as normal unleaded to prevent pinging
    this will also clean out the engine and make it run better and better over time as it rids the engine of carbon
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Apr 2004
    Geelong
    168
    I've recently changed to premium in an old 280 Benz can't believe the difference over LRP , but, I was under the impression that using unleaded without a cat was a no no due to the emissions, anybody know what the official view is.
    Graham Lewis
    9,287
    Quote Originally Posted by Graham Lewis
    Graham Lewis
    There's no choice since lead dissappeared in 2000.
    The concern was about benzene, a carcinigen. (spelling?)
    Apparantly 91 octane has less benzene than leaded used to have. Premium has a little more.
    BP Ultimate (and BP in general due to their more advanced refinery) has a very low level of Benzene, the fuel to use if you are worried about benzene emissions.
    Graham
    mlb
    mlb is offline
    Voted Most Popular mlb's Avatar
    Jan 2005
    Devonport, Tasmania
    1,103
    Is a certain amount of pinging, even when running on PULP normal? Without resorting to methods like water injection, etc, is there anything else that can be done to prevent/reduce it? And can it result in damage to the engine if left to run like that in the long term?
    Matt
    Fight for your opinions, but do not believe that they contain the whole truth, or the only truth.
    12,269
    you can prevent it in a couple of ways if it happens
    retard the ignition
    or decoke the engine
    decoking is as easy as either running a little bit of water down the carb or my prefered method is using redex
    when using redex just watch the great plumes of smoke that billow out the rear
    gradually pour around 250ml of redex down the carb at around 1500rpm with the engine at running temp then take the car for a run to expell any residue then run the redex in the tank for a while to rid any left overs
    if after decoking you still have pinging you will need to back the timing off around 2deg
    1 x 2018 3008
    Fellow Frogger! Westair's Avatar
    Jan 2005
    Perth
    558
    I run my 280E and VW Campers on premium and the difference is fantastic. Better mileage and smoothness. Dash of flashlube occasionally.
    We used to decoke with brake fluid down the carby-really cleans them out but don't stall engine. It cooks everywhere.
    1986 Renault Fuego GTX
    1972 Mercedes Benz 280E
    1988 Nissan Trakka Campervan
    1972 VW Kombi
    In business, words are words; explanations are explanations, promises are promises, but only performance is reality.
    Harold Ganeen.
    Fellow Frogger! seesully's Avatar
    Sep 2003
    Middle Park, Melbourne
    260
    Quote Originally Posted by mlb
    Is a certain amount of pinging, even when running on PULP normal? Thanks Matt
    Used ULP a few times when I first got my 505 and it pinged... Lots... Now I only use PULP. Economy has improved dramatically and it doesn't ping at all, not even when it's fully loaded up steep hills....
    So, in short, your's shouldn't ping hile using PULP....
    Les hurlements de lion.
    504 GL (gone)
    205 GTI Classic (gone)
    505 STI (gone)
    I can feel a GTI 180 coming on!
