I'm currently in the process of installing a Bluetooth handsfree kit for my Sony Ericsson phone in my 2000 206 GTi 138. The kit requires a power supply, and comes with a 3A fuse. I want to do a nice clean install, wiring this through the interior fuse box, using one of the empty slots. A few questions:
1) Is this a good idea? Or am I going to break something?
2) What kind of connector do I need on the end of the wire that will run out the back of the fuse block to the handsfree, and where would I obtain it from? Would a Peugeot dealer's parts dept be able to help me out? I tried a standard female blade connector (of the sort you can get from Bunnings, etc), but it didn't fit all the way into the holes in the back of the fuse block.
3) The kit also requires an ignition feed so that it is aware when the key's been turned. I'm assuming this is one of the fat wires that run to/from the key barrel, but I'm not sure which one. I know Haynes make a workshop manual for the 206 that includes wiring diagrams, but the manual doesn't cover the GTi. Would the wiring diagrams from this book still be applicable? Anyone know off the top of their head which wire it would be?
