505 Coolant Level Sensor
Results 1 to 11 of 11
    mlb
    mlb is offline
    Voted Most Popular mlb's Avatar
    Jan 2005
    Devonport, Tasmania
    1,103
    Default 505 Coolant Level Sensor
    I understand that the 505's had an alarm for when the car had a low coolant level. My car looks like it is missing that as there is just a straight cap on the radiator, no sensor.
    Could someone please give me a quick outline of the system, what alarm it triggered, and what coloured wire went to the sensor. I am looking at re-establishing the system and need to sort it all out.
    Matt
    Fight for your opinions, but do not believe that they contain the whole truth, or the only truth.
    9,290
    Quote Originally Posted by mlb
    Matt
    The GR didn't have it, On the GTI the overheat light doubles as low coolant level
    Graham
    mlb
    mlb is offline
    Jan 2005
    Devonport, Tasmania
    1,103
    Graham
    That would explain its absence. Thanks Graham.
    Any chance of retrofitting fitting one?
    Matt
    9,290
    Matt
    You would need to fit a GTI filler system, the GTI radiator has the hoses on the other side, so you can't direct swap, and an overflow bottle. You could wire to your existing light, this comes off the sensor in the back of the head. This is a switch unlike 504s and 404s which have a thermistor for the temp guage in this spot.
    Graham
    mlb
    mlb is offline
    Jan 2005
    Devonport, Tasmania
    1,103
    Graham
    By the sound of it the 505 has two different temperature connections. One for the gauge and one for the light. Am I correct in this? The one for my gauge obviously works as my gauge moves around as it should, but where exactly is the one for the light, as I have the feeling that mine may be diconnected . I have a loose wire floating around in my engine bay that looks like it needs to clip onto somewhere.
    9,290
    As I said the one for the light goes to the back of the head .
    The one for the gauge goes to the waterpump, not to the carbon brush for the clutching fan but to a sensor screwed into the waterpump body.
    Graham
    Hobart
    1,496
    Graham Matt,
    505 SR has the radiator with the coolant level and expansion bottle, they also have the inlet and outlet on the same side *like the GR*
    Ben
    1989 Peugeot 405 Mi16
    2000 Peugeot 306 XSI
    1973 Peugeot 504 GL
    mlb
    mlb is offline
    Jan 2005
    Devonport, Tasmania
    1,103
    Graham
    Is this where the switch for the temperature light is? If it is I will have to replace it As you can see the tang for connecting the wire to is non-existant.
    I also solved the mystery of an unattached wire that's been floating around under my bonnet. I put it to ground and low and behold the temperature light came on . So I may have to get that hooked up again.
    On a hunch I decided to check the other alarm lights. Put the oil sensor to ground and the alternator light came on. Checked the alternator, and the oil light came on . Obviously that is now fixed. I feel like the marketing manager for Microsoft, but instead of 'Where do you want to go today' it's more 'What will you find today'
    The search for truth continues
    Matt
    Attached Thumbnails Attached Thumbnails 505 Coolant Level Sensor-100_1245.jpg
    Hobart
    1,496
    Hey Matt,
    I've got some of those here, want me to bring one up ?
    Ben
    PS anything else you want let me know as Monday is the day i'm coming up !
    1973 Peugeot 504 GL
    Tadpole groongal's Avatar
    Jan 2005
    CARRATHOOL, NSW
    21
    Default Coolant level sensor
    Graham
    The 505SRD has a true coolant level sensor located in the coolant overflow bottle. In my experience, the sensor is prone to giving many false alarms!
    mlb
    mlb is offline
    Jan 2005
    Devonport, Tasmania
    1,103
    Quote Originally Posted by Pug_405_Mi16
    Hey Matt,
    Ben
    That would be good if you could bring one up Ben.
    Also would you have a driver's side external door handle floating around. As well as a washer motor from a GTi- I got the bottle from the one in Launceston but the motor was u/s . Also has the door strap you had earlier returned from the parallel dimension into which it was sucked?
    Matt
    PS I'll give you a call on Monday somewtime
