Electrics
Thread: Electrics
    Wellington New Zealand
    8
    Electrics
    Is it possible to have all 4 spots running at once in a 309gti?
    When things just stop working ie electric windows, high stop lights are there any things that usually cause this when its not fuses? Like a bad contact etc?
    Help would be excelent as my drivers window is stuck down
    Nath
    Oct 2000
    Auckland, New Zealand
    533
    I'm not quite sure what your problem is but once with a primera of my dad's all the electric windows stopped working at once, so we took the panel of the drivers door and the connector of the drivers window control panel at come out, plugged it in and they all worked, maybe that will work or i've missed your actual problem.
    12,269
    check for a bad earth in the car
    i had a similar problem once with a 604 (now people don't start on the poor machine they weren't that bad )
    they had an earth under the centre console that if it wasn't earthed properly the switches for the roof and windows would go haywire
    my 10 cents worth anyway
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    8
    Hmmmm that sounds like it may be thr problem as one of the interior lights has stopped working.
    You dont happen to know where i might find this earth exactly just as there are alot of wires under there and a general area to start looking in would be great.
    Nath
    nsw
    41
    If it the same as a 205, there are earths on the steering column under the plastic shroud.
    There are also earths inside the doors.
    8
    Well what do you know?
    I get up this morning and replace a fuse for the window wipers and everything works just fine!
    But what the hell do the wipers have to do with the circuit for the windows?????
    Strange cars!!!
    Nath
