306 ECU info
Results 1 to 7 of 7
Thread: 306 ECU info
    490
    306 ECU info
    Was wondering if anyone can help me with the type of ECU the 6 has... is it a Bosch?
    Also, does an ECU reset entail disconnecting the battery for a while, and running the car at idle for a specified time?
    392
    Gday
    Im not sure if it is a bosh ecu on teh 306's but, fro resitting it all u do is dissconnect the battery fro 90 seconds then reconnect it and turn the ignition to teh on postion fro 90 seconds, I have odne this not long ago and thats how the peugeot mechanic told me to do it.
    rek
    rek is offline
    1000+ Posts rek's Avatar
    Melbourne, Vic
    1,388
    Originally posted by ntrx:
    <STRONG>Was wondering if anyone can help me with the type of ECU the 6 has... is it a Bosch?
    </STRONG>
    I believe it has a Magneti-Marelli 1AP10 ECU. I haven't seen any official Peugeot spec-sheets confirming this, though.
    <STRONG>Also, does an ECU reset entail disconnecting the battery for a while, and running the car at idle for a specified time?</STRONG>
    wouldn't have the first clue! I would guess something like that would do it.
    Talking about ECUs, there is an ODBII connector on the fuse panel that's underneath the steering column. Apparently you can get a bit of diagnostic info from them, with the appropriate cable. (I saw Matthew Moyle-Croft's post on the 206 GTi board about them, and decided to take a peek under the 306 to see if it had one as well..)
    Peter
    2008 Saab 9-3 1.9 TiD Sportcombi
    2011 Volvo C30 DRIVe 1.6D
    490
    Thanks guys!
    ooh Magneti Marelli, sounds swish
    Hmm that OBDII cable Rek, do you reckon it's a matter of getting an appropriate cable and software for the notebook?
    Would be interesting to check what goes on.
    rek
    rek is offline
    Melbourne, Vic
    1,388
    <STRONG>ooh Magneti Marelli, sounds swish
    </STRONG>
    even better if you say it with an Italian accent.. :p
    <STRONG>Hmm that OBDII cable Rek, do you reckon it's a matter of getting an appropriate cable and software for the notebook?</STRONG>
    not sure. the scan tools that connect to a PDA cost US$200-300. Maybe with the added power of a laptop PC, some of the signals could be processed in software instead.
    This link gives some insight into the idea..
    really long and annoying URL
    [ 15 November 2001: Message edited by: rek ]
    Peter
    490
    thanks rek - very interesting.
    2000+ Brad's Avatar
    2,404
    Rek, you're a wealth of information.
