I went out for a long drive today.
Down to Cronulla for some fish and chips. Then the plan was to drive over the Old Princess Hwy down to Bulli Pass.
I got the fairly new roundabout where you can turn off to go to Stanwell Tops. Waited for the cars to clear so I could continue. All of a sudden, upon acceleration, I get major wobbles through the entire car. I can feel it though the gear lever, the steering wheel. And visually see the front of the car wobbling.
I am unsure of what this could be. It only does it on acceleration. It does it in every gear. 1st gear is the worst, 2nd not as bad, 3rd alittle less, and so on till 5th gear. Where it can just be felt.
Would this be the drive shafts? Diff? Gear box? CV? I turned a corner both left and right handers at full lock at slow speed to see if there were any noises. There are no noises at all. Although, now there is a thump after changing gear and hitting the accelerator, making me think engine mounts.
I've also noticed alot of low down power has gone. And when I stopped on the side of the road to check out the wobble. ie: Missing wheel balance weights, lost wheel studs. I pulled some stones stuck in the tread out, thinking that could be adding to the problem of the wobble. But yeah, power has gone as well.
I will be jacking the car up on a hoist tomorrow to have a better look. But in the meantime, any direction would be appreciated.
What I don't get is, how and why on earth would something like this happen? It's not one of those things that is caused by wear and tear. I would logically assume that it would be caused by hard driving. Which I was not doing. What would cause this?
Thanks,
pips
