Gear Knob removal - Series 1 405
Results 1 to 7 of 7
    Hobart
    1,496
    All,
    The gear knob on my Mi16 is starting to break up a bit so I thought I would replace it with the good one I have here....easy job so I thought!
    I have pulled, poked, and twisted it but to no avail ! there has to be a way to get it off?
    It's the type with the lift up thing for reverse!
    Ben
    PS for all those with dirty minds...yeah yeah
    1989 Peugeot 405 Mi16
    2000 Peugeot 306 XSI
    1973 Peugeot 504 GL
    Fellow Frogger! Andreas's Avatar
    Sep 2000
    1,200
    Pug_405_Mi16:
    Do what you've been doing but pull a bit harder...it'll come off sooner or later.
    Seriously though, I tried and had the same problem...ended up getting the hacksaw roll_lau
    May 2001
    Sydney, NSW, Australia
    3,635
    Pug_405_Mi16:
    Sorry Ben, can't really help you with how to get the knob off whistle but it's a dangerous topic on this forum :p Have a look at this thread I started and see how it went!
    <a href="http://www.aussiefrogs.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=3;t=001042" target="_blank">http://www.aussiefrogs.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=3;t=001042</a>
    Derek
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    Melbourne, Australia
    2,930
    How did I manage to forget about that memorable post?
    I considered replacing my gearknob, but it is at the bottom of my to-do list at the moment.
    Nick
    1983 Peugeot 505 GR
    Hobart
    1,496
    hmmmmm,
    Oh well I will keep on trying....
    Ben
    1973 Peugeot 504 GL
    310
    Hi, the gear nob on my Mi16 was broken in half, so i had to remove it to replace then new one.
    Method i used:
    I held the old Knob really tightly, pulled, yanked, swore, and it was finally detached from the stick..
    Wow, then put the new nob on, it wass a little stiff, so i hit it gently with a rubber mallet..
    How else do you explain it
    Good luck with your dilemma.
    Regards
    Adrian
    Peugeot
    "Anything else is a Compromise!"
    Lilydale, Melbourne
    2,095
    It's glued on. Get a hairdryer, try to melt the glue and you might be able to pull it off. It's supposed to slide straight off, it's not threaded.
    I once had plans to put a different gearknob on my S1, but gave up because I couldn't get the old one off.
    John
    John W
    1974 Peugeot 504 TI
    - now on the road
