205 S1 Tachymetric Relay Replacement
Results 1 to 2 of 2
    Fellow Frogger! nchandler's Avatar
    650
    Default 205 S1 Tachymetric Relay Replacement
    Morning all,
    205 is having that bloody intermittent starting problem, going to try replacing the tach. relay. I remember dino saying he fitted a 405 relay, and it fixed the problem. Is it a bosch part? If I could grab some details on what sort of tach. relay it is, would be great.
    Nick
    1000+ Posts dino's Avatar
    Nov 2002
    4,606
    its the same as the 405...same engine after all....you should be able to get one from wreckers ...reasonably cheap...I only paid app$20 for mine.....mind you, the used one may be close to death as well......What suburb are you in.....I can lend you my relay (car is still in pieces) and see if that sorts it out......I m assuming you ve got good plugs and all the connections have been checked....Did it play up yesterday...it was particularly hot and this relay seems to play up in the heat......I think I have a spare ignition module as well....
    cheers
    good luck
    you can PM me if you d like to try out my relay.....I m in south east.....
