206 GTI 180 - oil
Results 1 to 23 of 23
    Fellow Frogger! Dr_Pug's Avatar
    548
    Default 206 GTI 180 - oil
    Just wondering what brand/grade of oil you guys are using in your 180?
    Was told when doing a oil change with filter put in 4.5L then continually add whilst checking dipstic until it approaches full level. Is this what you guys are doing?
    04' GTi 180
    Fellow Frogger! qd180's Avatar
    Jul 2004
    Sydney/Seven Hills/Down Under
    220
    Quote Originally Posted by blackster
    Hey Blackster,
    I use Mobil 1 Super synth 5W50...... its the same stuff my dealer uses
    Trust me for a oil and filter change on the 180, the oil Sump will hungrily eat up all 5 litres and then some (top of my head 5.3L correct me if im wrong guys
    I usually get a 5L and a 1L bottle from a Mobil service station to make up the difference.
    Check this out for detailed instructions
    http://206gti.net/oilchange/
    "Racing is life, Everything else is just waiting" Steve McQueen 1930 - 1980
    Member QIK-516's Avatar
    Sep 2004
    Newcastle
    41
    Calling Jester_Fu to this thread
    You want to know anything about oils, he is about to tell you
    S16 ownership is like a fine french wine, perfection personified
    Member GTI145's Avatar
    Jun 2004
    54
    Spot on qd180...........
    5.3 litres.....
    GTI145
    '89 405 MI16
    '00 206 GTI
    '04 206 GTI 180
    Jul 2004
    220
    Quote Originally Posted by jester_fu
    I have read this thread, and can't see anything i disagree with except the Mobile Oil being used. But, each to their own.
    Its spelt "MOBIL" for the last time
    And whats wrong with the Super Synth5W50.... please explain
    what do you use????
    Jul 2004
    220
    On a car with 10k service intervals, it's not likely to make any difference to the engine life. Start throwing some hard driving in there (like open speed days) and it might be worth considering an oil change (no filter) after every track day. Oils react to heat, and their properties change. Synthetics are generally more resillient to heat and hard use, so it's less of a concern. But, if the oils syntheitc status was questionable, i'd be inclined to treat it like a semi-syn and drop it after each hard day. Just a little bit of insurance.
    I didnt know that
    Well its a good thing i drop the oil every 5000kms anyways
    After each 5000kms the oil still is clear and golden so i guess its doing well
    Free synthetic oil gimmie gimmie gimmie
    Gordon, NSW
    4,527
    Although Mobil 1 may have a fair amount of organic material in it, it doesn't mean it is necessarily a bad oil.
    I think 5,000km changes on Mobil 1 is going a bit far as well. You should do a filter change, drop the oil and top up with another litre, but going a full change of a full synthetic is a bit much. Every 6000kms or 6 months which ever comes first, that's what I'd do.
    What oil is actually recommended on the Pug? My ST uses 5W-30 which is quite a narrow range. I would think that a 5W-50 wouldn't have the level of stability that I'd want, but again, it depends on the car, I guess.
    I'm using a full diester based synthetic and am very happy with it. But I've also read tests of US Mobil full synthetic (which has Moly on it, where I don't think Australia's version has Moly) and tests on Amsoil's PAO based full synthetic and the Mobil peforms better. That's in an LS1, but the Mobil kept it's viscosity for longer than the Amsoil did.
    In any case, both are great oils and if you're changing it on time, and doing things like changing the filter...or even going overboard with 5000km changes with a full synthetic, then I don't think it really matters what you're using. A semi-synth would be fine with the 5000km change thing.
    1000+ Posts U Turn's Avatar
    1,761
    The mobil 5w50 oil which retails for around the $60/5L mark is as jester said not a true synthetic but based on mineral oil which has been refined highly. It is still considered a synthetic and most synthetic oils on the market are made from this base stock.
    However I believe there is another Mobil 0w40 (I think that's the correct weight) which retails for about $90/5L and this I believe is a true synthetic with a PAO base stock and is completely chemically engineered with no mineral base stock.
    An old AF thread posted some results from a lab test of various synthetics and from memory the Mobil 0w40 featured among the top three in performance across the board. However its 5w50 came second last I think. Doesn't mean it's a bad oil though as the comparison was amongst synthetics.
    Take the long way home....
    - 306 gti6
    Sep 2003
    North Parramatta
    3,997
    That seems a little high, Mr fu.
    Mine is very happy sitting at 90, with a little bit of urge (or 30 mins of Sydney peak-hour traffic), it rises to 95, but only goes to 100 and beyond with some serious driving - because as you know, the 180 has no torque down low and must be thrashed mercilessly to get it anywhere
    Oh and BTW, (trying to keep on topic...) I'm using a Motul full synth. 5W40 oil in mine at the moment. Lots of people seem to like the Elf Excellium stuff which is also 5W40.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Jun 2004
    54
    Speak to your friendly parts guy.. ..and he will say..."why not use Total???"
    We have all seen the sticker under the bonnet saying to useTotal/Esso
    I have always used Total Quartz9000 - 5w40 ....5,000km oil/filter change under $80
    Cheaper if you know your friendly parts guy!!
    My opinion is PSA is now one of the top 3 oil producers/suppliers after recently purchasing the remains of Exxon-Valdieze(???) and Shell EU.....so give the "GENIUNE ENDORSED" oil a go.......I think they know their stuff
    If anything goes wrong at least you can say " I have always used Total "
    Just maintain your oil change intervals...its the blood of your engine
    GTi145
    '89 405 MI16
    '00 206 GTI
    '04 206 GTI 180
    1,761
    Quote Originally Posted by SLC206
    I think the convection properties differ quite significantly between oils. You'll probably find that the Motul you're using is more efficient at transferring heat. I've found this with the Elf excellium 5w40 I'm using compared to the Mobil 5w50 I was using earlier. The car now runs consistently 10 deg cooler.
    - 306 gti6
    Gordon, NSW
    4,527
    GTI145, Total own Elf, I doubt there is much difference between their full synthetic 5W40 and Elf's.
    FYI, on Neo, my oil and engine temp did not rise above normal for the entire day at Wakefield. Now there's stability...or a high tolerance gauge...
    If I had a 180, I'd be running a 5W40, rather than a 50.
    1000+ Posts gti138's Avatar
    Adelaide, South Australia
    1,885
    Quote Originally Posted by jastanis
    Speaking of which - Are you interested in doing another order of that Elf Stuff in the early new year Jude?
    I dont have enough on hand for an oil change!
    Murray : And there are flames coming from the back of Prost's car as he enters the swimming pool!
    James Hunt: Well that should put them out then!
    Mallala: 1:30.79
    1,761
    Mike, yep no probs. I'm os at the moment but should be back in Oz in a couple weeks so will do it then. I also read in another thread that Elf excell' now comes in 5L x 3 packs. I'll give Onshore a call to confirm and see which way works out cheaper and order accordingly.
    - 306 gti6
    Gordon, NSW
    4,527
    Jude, what are you running in the 6? 5W-40? Use any oil at that viscosity? That's a bit thin... I used to run 10W-40...Amsoil. It's kinda hard to find a !0W-40 nowadays, I guess a 5W just gives you a bit more range...
    Scott, do you get viscosity tests done as part of your tests? How does your hold it's viscosity through it's life?
    Dec 2004
    caves beach
    4
    Default Service
    Jester what do you think of Regal motors service department?
    I assume you take the car there .
    Seems like abit of a waste changing synthetic oil every 5000k's
    Jul 2004
    220
    Same mine runs at 90 constant and about mid ninty's in traffic
    At Wakefield though late into the day i ran a full session (first car out and then flagged in for next session) and my oil rose to 130deg
    The reason i do a filter/oil drop every 5000km is that the car is only driven on weekends enthusiastically
    plus ive got a contact that gets it at trade price any hows
    Im just over cautious
    What happens with mixing oils??? i would be lead to believe that its not good for said engine ( my car will be getting the 20K service at dealer where they use mobil 5W50 Hence the reason to why i use it)
    Gordon, NSW
    4,527
    No, not really, SLC. It was a hot day (about 30degree C ambient Temp + hotter on the track), and the car was being pushed fairly hard in the rev department. I think considering all, it held up pretty well. My temp normally sits anywhere between 90 and 100 (hence i said about 100) around town or on a long trip on a hot day wit hall accessories running. It's certainly not as stable as the GTi138 or the Mi16 engines.
    And yes, i know ooohhhh sooo weell that the 180 needs to be flogged like a dead horse to get it moving
    You know what was weird? When I drove the 180, it's temps stayed fairly normal. When you drove it, it went up. When I drove my ST, it's temps stayed normal, but when you came in with it, it's temps were up... I didn't have a really good look, but I thought I saw the temp above normal.
    Driving style? Not getting enough air in? Too much braking? Was a strange observation I made on the day.
    Gordon, NSW
    4,527
    Oh, I meant on the track, not when you came in. Of course when you come in and sit there idling without air coming in the temp would go up...although even then the Ford stayed normal. Freaky thing.
    Anyway, could just be an air flow thing... or an overly sensitive temp gauge on the Pugs versus the Ford.
    My car is back to normal now and isn't craving revs as much as it was for the first couple of days after the track day.
    re: oil, I'll be running this diester based oil for at least one more change.
    548
    Hmm, this thread has gone a bit off topic
    Thanks for the replies that were on topic.
    So i guess 5.3L with filter and mobil 5w 50 are pretty much alot of peoples choices.
    04' GTi 180
    Gordon, NSW
    4,527
    You're such a good driver, Scott, you make my car fully hot, man! sik!
    Yeah, I'd agree with most of what Scott just said, except for the 10W comment. Castrol and Elf both make a 5W-40 full synthetic which would be what I'd be going for... the Elf more than the Castrol.
    1,761
    Quote Originally Posted by GTI124
    Lincoln, I'm running the Elf Excellium 5W40 at the moment. The 5 weight is a bit of an overkill for Oz's winters but I'm not aware of a well priced 10W40 that is as good as the Elf. I don't think 5W40 is too thin though. At 100 deg C, a 5W40 has the same viscosity as a 15W40! Also today's synthetics are capable of handling a wide viscosity range.
    - 306 gti6
    Sep 2003
    North Parramatta
    3,997
    When I first dumped the oil (at around 1500k I think) I used Mobil 1 0W40 in it, and the oil temp was sitting a bit higher - much like jester describes with his oil temp I guess. It was also much more prone to variations in temp. Definitely the Motul 5W40 stuff makes the temp behave much more like the old 138 did - stable - though not as much.
    I can't give a good reason why I would not use a 5W50, but I just wouldn't
    Simon
